Transfer attribute data from one polyline to another
3263
02-25-2016 08:51 AM
LuisGalimberti1
Hi there,
I have two different sets of center lines (none attributes in common).  I am trying to transfer the attribute data from one to another.  I tried to use Thiessen polygons to achieve this but it does not work.  I ran out of ideas so I will appreciate if someone can help me out with this.
EarlSarow
Take a look at the "Transfer Attribute" tool, in the "Conflation" toolbox.  It's designed to do what you are trying to do here.
You might need to add attribute fields to your "target" features to receive the values from the source features.
Transfer Attributes—Help | ArcGIS for Desktop
AdrianWelsh
MVP Honored Contributor
Could you perform a spatial join? This may help what you are doing
Spatial Join—Help | ArcGIS for Desktop
LuisGalimberti1
Hi Adrian,
Thanks for the message. I have already tried the spatial join. The problem is that the polylines are also segmented differently, and I couldn’t find a way to set more rules the moment that I did the spatial join.
EarlSarow
