How to use ITopologicalOperator with vb.net?
2686
02-18-2016 11:23 PM
karthikm
Dear all,
            I am using arcmap 9.3 with VB.Net. I need to get the adjacent building so i am using the Itopological operator for get the building. i am doing following coding but i am not complete the coding i have struggle please any one help me for complete the coding.
Sub exampleITopologicalOperator_Buffer(ByVal x As Double, ByVal y As Double)
  Dim featureCursor As IFeatureCursor
        Dim ptc As ESRI.ArcGIS.Geometry.IPointCollection, i As Long, pa As ESRI.ArcGIS.Geometry.IArea, ptopo As ESRI.ArcGIS.Geometry.ITopologicalOperator
        ptc = New ESRI.ArcGIS.Geometry.Polygon
        Dim pt(4) As ESRI.ArcGIS.Geometry.IPoint, poutPoly As ESRI.ArcGIS.Geometry.IPolygon
        'The spatial reference should be set here using IGeometry::SpatialReference (Code skipped here) 344011.132111 6300045.490245
        For i = 0 To 4
            pt(i) = New ESRI.ArcGIS.Geometry.Point
        pt(0).PutCoords(x + 0.5, y)
        pt(1).PutCoords(x, y + 0.5)
        pt(2).PutCoords(x - 0.5, y)
        pt(3).PutCoords(x, y - 0.5)
        pt(4).PutCoords(x + 0.5, y)
        Dim geometryBride As ESRI.ArcGIS.Geometry.IGeometryBridge
        geometryBride = New ESRI.ArcGIS.Geometry.GeometryEnvironmentClass()
        geometryBride.AddPoints(ptc, pt)
        pa = ptc
        ptopo = ptc
        poutPoly = ptopo.Buffer(-1) 'inside buffer
        pa = poutPoly
        Dim SpatialFilter As ISpatialFilter
        SpatialFilter.Geometry = poutPoly
        SpatialFilter.SpatialRel = ESRI.ArcGIS.Geodatabase.esriSpatialRelEnum.esriSpatialRelOverlaps
    End Sub
nicogis
when you have your polygon you can use a spatial relationship with a shape comparison language string for select polygon adjacent:
use F***T****  9IM    F => interior-interior (false) e T => boundary-boundary (true)    * =>  not tested (not need for your comparision)
for details 9IM Shape comparison Language
' Get the feature with the known oid
Dim caFeature As IFeature = featureClass.GetFeature(4)
Dim caGeometry As IGeometry = caFeature.Shape
 ' Create a spatial filter with a 9IM spatial relationship.
Dim spatialFilter As ISpatialFilter = New SpatialFilterClass()
spatialFilter.Geometry = caGeometry
spatialFilter.GeometryField = featureClass.ShapeFieldName
spatialFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelRelation
spatialFilter.SpatialRelDescription = "F***T****"
spatialFilter.SubFields ="yourfield1, ..." ' Execute the query.
Dim selectionSet As ISelectionSet = featureClass.Select(spatialFilter, esriSelectionType.esriSelectionTypeSnapshot, _                                     esriSelectionOption.esriSelectionOptionNormal, Nothing)
karthikm
Dear Domenico,
                     Thank you for your response it will be helpful for me thanks so much.
