Pan/Rotate
2344
5
02-09-2016 01:29 PM
KihanaMixon
I am embedding the earth into an application using a custom QWebEngineView (Qt 5.5) and ArcGIS API for Javascript 4.0 beta.  The earth is displayed properly.  I can zoom in/out using the mousewheel or double clicking.  I can NOT pan or rotate.  Using a MapView I was able to pan and rotate, but SceneView is not allowing it.  Anyone know what the problem may be?
Tags (4)
RickeyFight
MVP Regular Contributor
Can you check the console log and post any errors you might be having?
KihanaMixon
I saw some ad-blocking data, but I saw that when using a MapView as well.  I disabled my ad blocker but still not able to pan/rotate.
RickeyFight
Can you post your code or a similar sample to see if we get the same results?
KihanaMixon
Please find code attached.
KihanaMixon
It's been a while now, did you try the sample code I provided and get the same results?
