Dynamically change the infotemplate on a feature layer
3178
01-29-2016 11:50 AM
JasonLevine
I have a feature layer that I've constructed from a url, and have applied a feature template to it to display a popup when a feature is clicked.  I also have a feature layer that I've constructed from a feature collection object (not a url) that I have applied a separate infotemplate to.  For the latter, the infotemplate displays data in a popup window for, let's say, fields X, Y, and Z; this looks something like: featureLayer.setInfoTemplate(new InfoTemplate('$X','Name: $Y <br/>Type: $Z'));  This displays a popup where the value for X is displayed as the title, and the contents are values for Y and Z.  However, sometimes the value for Y is an empty string, and when this occurs, I'd like to not display field Y in my popup.  How can I check for the value of Y when the feature is clicked so that I can dynamically alter the infotemplate to not show Y if it is an empty string?
Jason
TracySchloss
Honored Contributor
You need to use a function for setting the content of your infoTemplate.  If you search the forum for infotemplate.setcontent, I'm sure you'll find several examples.  I end up using a function over half the time.  Instead of using ${fieldName}, you'll use graphic.attributes.fieldName.  The function can get quite long, depending on the number of attributes and how many you're checking for empty values.
var myInfoTemplate  = new InfoTemplate("your Title");
myInfoTemplate.setContent(generateInfoContent);
function generateInfoContent(graphic) {
var formatString = "myFieldName:" + graphic.attributes.X;
var checkY = graphic.attributes.Y;
//only appends if there is a value for attribute 'Y'
     if (checkY} {
          formatString += checkY;
formatString += graphic.attributes.Z;
return formatString;
TracySchloss
Honored Contributor
     if (checkY} {
JasonLevine
Thanks Tracy, that's exactly what I needed!  I didn't realize you could feed a function into setContent.
-Jason
TracySchloss
Honored Contributor
I don't think it's well documented at all, for something so versatile.  It makes me wonder what else we're overlooking!
