Partial refresh not working when layout graphics exist
2359
01-27-2016 08:50 PM
NavinSushil
I'm experiencing strange behaviour in ArcGIS v10.3
Adding layout graphic elements to all 4 corners of our map will result in a full refresh every time a point feature is moved.
Things that I've noticed are:
a) If I delete the graphic elements, ArcMap will perform a partial refresh using the extents of the feature being moved, which in my case is a point feature with a tiny extent so the refresh is super fast.
b) If we only have 2 graphic elements (1 in corner, 1 in center), ArcMap will create a bounding box between these graphic elements and refresh that area, regardless of where my point feature is (ie a partial refresh will occur around my point feature as well as the bounding box between the graphic elements)
Has anyone else come across and/or fixed this issue?
Cheers,
-Nav.
