No basemap causing error
5137
7
01-19-2016 05:36 PM
TiakiRice
I am trying to create a web based map viewer which consists of a single Map Service with no base map layer.
I have managed to do this with the 3.15 API by specifying no base map, however when I try to do this with the 4.0 API beta the layer is displayed but I get the following error on load:
Uncaught TypeError: a.constrain is not a function
Additionally when I try to zoom or pan the map I get the following error:
Uncaught TypeError: this.constraints.constrain is not a function
Here is my javascript code:
var map;
var layer ;
var view;
require(
                    "esri/Map",
                    "esri/views/MapView",
                    "esri/layers/ArcGISDynamicLayer"
                function(
                        Map,
                        MapView,
                        ArcGISDynamicLayer,
                    layer = new ArcGISDynamicLayer({
                        url: "http://my.service.url"
                    map = new Map({
                        layers: [layer]
                    view = new MapView({
                        container: "map",
                        map: map,
                        ui: {
                            components: ["compass"]
Also if I put in a basemap everything works correctly.
RickeyFight
Byron,
Look here: Local scene grid
It looks like at this point you cannot remove a basemap.
Kristian Ekenes
TiakiRice
That is in SceneView, would the same apply to MapView?
KristianEkenes
This is a bug that we're working on fixing for the 4.0 final release.
TiakiRice
Thanks for the info Kristian!
MichaelMatuszak
Given this issue, has anyone been able to successfully create their own custom Basemap? I've tried creating an instance using the url to one my locally-hosted tiled services, but the URLs it generates to request tiles seem to be off.  My services were using a state-plain spatial reference (WKID 4269), which I passed as an option.  Is it possible that it expects a Basemap to be in a specific spatial reference, or be generated a particular way?  If anyone has any guidance or could provide a working code example I'd be much obliged.
YannCabon
I create a temporary workaround here: JS Bin - Collaborative JavaScript Debugging
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>MapView</title>
  <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/4.0beta3/esri/css/main.css">
  <style type="text/css" media="screen">
    html, body, #mapDiv {
      width: 100%;
      height: 100%;
      padding: 0;
      margin: 0;
  </style>
  <script src="//js.arcgis.com/4.0beta3/"></script>
  <script>
    var map, view;
    require([
      "esri/Map",
      "esri/Basemap",
      "esri/layers/Layer",
      "esri/layers/ArcGISDynamicLayer",
      "esri/layers/support/TileInfo",
      "esri/layers/support/LOD",
      "esri/geometry/Point",
      "esri/geometry/Extent",
      "esri/geometry/SpatialReference",
      "dojo/domReady!"
    ], function (
      Map, Basemap,
      Layer, ArcGISDynamicLayer,
      TileInfo, LOD,
      Point, Extent, SpatialReference,
      MapView
      map = new Map({
        layers: [
            url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/PoolPermits/MapServer"
        basemap: new Basemap({
          baseLayers: [
            new Layer({
              viewModulePaths: {},
              initialExtent: new Extent(-20037508.342787, -20037508.342780, 20037508.342780, 20037508.342787, SpatialReference.WebMercator),
              tileInfo: new TileInfo({
                rows: 256,
                cols: 256,
                dpi: 96,
                format: "PNG8",
                compressionQuality: 0,
                origin: new Point({
                  x: -20037508.342787,
                  y: 20037508.342787,
                  spatialReference: SpatialReference.WebMercator
                spatialReference: SpatialReference.WebMercator,
                lods: [
                  new LOD({ level: 0, scale: 591657527.591555, resolution: 156543.033928 }),
                  new LOD({ level: 1, scale: 295828763.795777, resolution: 78271.5169639999 }),
                  new LOD({ level: 2, scale: 147914381.897889, resolution: 39135.7584820001 }),
                  new LOD({ level: 3, scale: 73957190.948944, resolution: 19567.8792409999 }),
                  new LOD({ level: 4, scale: 36978595.474472, resolution: 9783.93962049996 }),
                  new LOD({ level: 5, scale: 18489297.737236, resolution: 4891.96981024998 }),
                  new LOD({ level: 6, scale: 9244648.868618, resolution: 2445.98490512499 }),
                  new LOD({ level: 7, scale: 4622324.434309, resolution: 1222.99245256249 }),
                  new LOD({ level: 8, scale: 2311162.217155, resolution: 611.49622628138 }),
                  new LOD({ level: 9, scale: 1155581.108577, resolution: 305.748113140558 }),
                  new LOD({ level: 10, scale: 577790.554289, resolution: 152.874056570411 }),
                  new LOD({ level: 11, scale: 288895.277144, resolution: 76.4370282850732 }),
                  new LOD({ level: 12, scale: 144447.638572, resolution: 38.2185141425366 }),
                  new LOD({ level: 13, scale: 72223.819286, resolution: 19.1092570712683 }),
                  new LOD({ level: 14, scale: 36111.909643, resolution: 9.55462853563415 }),
                  new LOD({ level: 15, scale: 18055.954822, resolution: 4.77731426794937 }),
                  new LOD({ level: 16, scale: 9027.977411, resolution: 2.38865713397468 }),
                  new LOD({ level: 17, scale: 4513.988705, resolution: 1.19432856685505 }),
                  new LOD({ level: 18, scale: 2256.994353, resolution: 0.597164283559817 }),
                  new LOD({ level: 19, scale: 1128.497176, resolution: 0.298582141647617 })
        container: "mapDiv",
        center: [-100, 40],
        zoom: 4,
        map: map
      map.layers.getItemAt(0).then(function(layer) {
        view.extent = layer.fullExtent;
  </script>
</head>
<body>
  <div id="mapDiv">
  </div>
</body>
</html>
MichaelMatuszak
Thanks a ton, that works perfectly.
