Cannot Delete Records
4590
01-04-2016 09:25 AM
cedwards8511
I have a layer with 14 records in its table, but only 11 features on the map.  Three records don't seem to be on the map, and I cannot figure out how to remove them.
I can only see the records of the Table is open, they do have info entered, bun cannot edit the Table.  When I go into an Edit session, there are no feature for these records to select, so I cannot delete them.
I really need to get rid of these, any suggestions?
JakeSkinner
Esri Esteemed Contributor
Hi Carey,
Try going to the REST URL of the feature service:
Then scroll to the bottom and you should see 'Delete Features'.  You can enter the OBJECTIDs of the features you would like deleted.
JakeSkinner
Hi Carey,
cedwards8511
Thank you, I had tried that once and failed.  I think I forgot to select Polyline for the feature type.  It worked this time though, so I am grateful.
JacobAalfs
When I go to the URL, I get message that a token is required.
