Rendering the Secure Service Prompt in beta 4
2859
12-30-2015 04:02 AM
NicoleSchmidt
Using this sample (or any I have tried):  ArcGIS API for JavaScript Sandbox
When you use a secure service which causes a prompt, you get this.  I assume that there is some css tweaking that could get this looking decent, but is that the best solution?  Or is there a better way to handle this that I am missing?
Tags (1)
RobertScheitlin__GISP
Nicole,
   You just need to add a dojo theme like claro or tundra:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>FeatureLayer - 4.0beta3</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.0beta3/esri/css/main.css">
  <link rel="stylesheet" href="https://js.arcgis.com/4.0beta3/dijit/themes/tundra/tundra.css">
  <script src="https://js.arcgis.com/4.0beta3/"></script>
  <style>
    html,
    body {
      padding: 0;
      margin: 0;
  </style>
  <script>
    require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/FeatureLayer",
        "esri/geometry/Extent",
        "dojo/domReady!"
      function(
        Map, MapView,
        FeatureLayer, Extent
        var map = new Map({
          basemap: "hybrid"
        var view = new MapView({
          container: "viewDiv",
          map: map,
          extent: new Extent({
            xmin: -9177811,
            ymin: 4247000,
            xmax: -9176791,
            ymax: 4247784,
            spatialReference: 102100
         * Add feature layer
        // Carbon storage of trees in Warren Wilson College.
        var featureLayer = new FeatureLayer({
          url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Landscape_Trees/FeatureServer/0"
        map.add(featureLayer);
  </script>
</head>
<body class="tundra">
  <div id="viewDiv"></div>
</body>
</html>
Nicole,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body {
      padding: 0;
      margin: 0;
  </style>
  <script>
    require([
        "esri/Map",
        "dojo/domReady!"
      function(
        Map, MapView,
        var map = new Map({
          basemap: "hybrid"
          map: map,
            xmin: -9177811,
            ymin: 4247000,
            xmax: -9176791,
            ymax: 4247784,
         * Add feature layer
  </script>
</head>
</body>
</html>
NicoleSchmidt
Robert,
Thank you!  That worked great.
