Alex,
This will get you started (only tested for polygons):
Your use of a lower case "d" for DataTable on line 35 caused a real issue in your code.
function addToMap3(results) {
map.graphics.clear();
var featureArray = results.features;
if (featureArray && featureArray.length > 0) {
// do stuff with the features
arrayUtils.forEach(featureArray, function (feat) {
feat.setSymbol(symbol8);
map.graphics.add(feat);
var extent = esri.graphicsExtent(map.graphics.graphics);
map.setExtent(extent, true);
var cols = [],
row = [],
data = [],
selected = [];
//create columns
$.each(results.fields, function (index, value) {
cols.push({
'sTitle': value.name
//create columns
//create rows and push into data
$.each(results.features, function (index, value) {
row = [];
$.each(value.attributes, function (index2, value2) {
row.push(value2);
data.push(dojo.clone(row));
var table = $('#example').DataTable({
dom: 'Bfrtip',
data: data,
columns: cols,
destroy: true,
buttons: ['copy', 'csv', 'excel', 'pdf', 'print'],
"rowCallback": function (row, data) {
if ($.inArray(data.OBJECTID, selected) !== -1) {
$(row).addClass('selected');
$('#example tbody').on('click', 'tr', function () {
var d = table.row( this ).data();
if ($(this).hasClass('selected')) {
$(this).removeClass('selected');
} else {
table.$('tr.selected').removeClass('selected');
$(this).addClass('selected');
if(feat.attributes["OBJECTID"] === d[0]){
map.setExtent(feat.geometry.getExtent().expand(2.5));
} else {
// do stuff when no features were found
alert("No features found")
