KML drawing lines from local html
3540
10-25-2015 08:34 AM
BetzRacovsky
Hi there,
I've tested my own KML of polygons with one of the online JS samples sandbox and it was working fine.
When I downloaded the html locally, the layer of the KML came up with lines in some places.
Any idea  anyone ?
B.
omega_cancer
Is your KML file publicly accessible?
because according to API Docs
Note: The KMLLayer uses a utility service from ArcGIS.com, therefore your kml/kmz must be publicly accessible on the internet. If your kml/kmz files are behind the firewall you will need to set the esriConfig.defaults.kmlService to your own utility service. (Requires Portal for ArcGIS).
require(["esri/config"], function(esriConfig) {
  esriConfig.defaults.kmlService = "http://www.example.com/arcgis/sharing/kml";
RebeccaStrauch__GISP
This appears to be a duplicate post of Grid Lines on KML Layer
