Grid Lines on KML Layer
3309
10-27-2015 02:54 AM
BetzRacovsky
Hi there,
I'm loading a map using KML which I created.
When loading the KML via one of the sandbox all looks good.
When I use the exact same code locally in HTML file , i get grid lines coming on the layer.
The KML is a combination of polygons.
Please see below the one with the lines and the one without.
Please can someone assist?
Betz
omega_cancer
Is your KML publicly accessible? Because according to API Docs
Note: The KMLLayer uses a utility service from ArcGIS.com, therefore your kml/kmz must be publicly accessible on the internet. If your kml/kmz files are behind the firewall you will need to set the esriConfig.defaults.kmlService to your own utility service. (Requires Portal for ArcGIS).
require(["esri/config"], function(esriConfig) {
  esriConfig.defaults.kmlService = "http://www.example.com/arcgis/sharing/kml";
