How to do Eliminate Datamanegement for list of layers?
2920
10-23-2015 02:16 AM
PhoukhongPhongsa
How to process with a list of files using [arcpy.ListFeatureClasses] with script below? Any help from you all very appreciate!
try:
  fcList = arcpy.ListFeatureClasses("P*","POLYGON")
  fcList.sort()
  print fcList
  fcCount = len(fcList)
  print fcCount
  for fcs in fcList:
      print "Selecting areas < 1ha from file: " + fcs
 eliminate_file = fcs + "_elim"
 arcpy.SelectLayerByAttribute_management(fcs,"NEW_SELECTION", expres)
      arcpy.Eliminate_management(fcs, eliminate_file, "AREA", "", "" )
except:
  print "Could not create feature layers"
This is from:
# Name: Eliminate_Example2.py
# Description: Eliminate features based on a selection.
# Import system modules
import arcpy
# Set environment settings
arcpy.env.workspace = "C:/data/Portland.gdb/Census"
# Set local variables
inFeatures = "blockgrp"
tempLayer = "blocklayer"
expression = '"Area_Sq_Miles" < 0.15'
outFeatureClass = "C:/output/output.gdb/eliminate_output"
exclusionExpression = '"OBJECTID" = 9'
# Execute MakeFeatureLayer
arcpy.MakeFeatureLayer_management(inFeatures, tempLayer)
# Execute SelectLayerByAttribute to define features to be eliminated
arcpy.SelectLayerByAttribute_management(tempLayer, "NEW_SELECTION", expression)
# Execute Eliminate
arcpy.Eliminate_management(tempLayer, outFeatureClass, "LENGTH",
​                           exclusionExpression)
Message was edited by: Dan Patterson I moved this to geoprocessing and used syntax highlighting >> to format the code
Pieter_Geertvan_den_Beukel
if only the last layer in fcList is processed, you have to check the indention of your code: the Eliminate must be inside the For loop
Not:
for fcs in fcList:
But:
for fcs in fcList:
WesMiller
Your code has a few errors in it.
I don't see where you set the workspace or the expression. Lines 9 and 10 have indentation errors.
Here is the help for Eliminate
Eliminate—Help | ArcGIS for Desktop
PhoukhongPhongsa
I have seen the Eliminate Help and copied the ...Example2.py
However, I want to process a list of layers or feature layers and do not knowhow to use Phyton or arcpy correctly.
I try to use this but no success!!!
for fc in fcList:
    MakeFeatureLayer...
    Select...
    Eliminate...
So, it process only the last layer in the fcList.
Any idea?
Thank you so much!
Phoukhong
PhoukhongPhongsa
I would like to Eliminate an area smaller than 15000 sq meters in all layers. Example files attached.
Dropbox - ElimSampleFiles.gdb.zip
Phoukhong
Not:
for fcs in fcList:
But:
for fcs in fcList:
