Edit Geoprocessing service
2466
10-27-2015 07:05 AM
TerryGustafson
I'm wondering if you can manually edit data paths for a geoprocessing service that is running on your Arcserver that is on Linux?  I have a model that I have created that works when I run it in ArcMap unless I set the final segment as an output parameter.  The final tool in the model is a make route event layer.  The problem is the event points file is in memory.  I have tried to export the model to a python script and set the parameter and point the points file to in_memory location but  when I create the tool from the python script and run it, it just errors out. I'm trying to find another option to get this thing to work.  TIA for any help or direction
