Line Decorations in ArcPro
1968
10-13-2015 09:40 AM
RonKnepper
Occasional Contributor II
Ok so I am used to ArcGIS and trying to force myself to learn all the common items in ArcPro, can someone help direct me where to set up line decorations in ArcPro?  I need to add a directionality arrow to the end of my lines.  In ArcGIS I would go into the Symbol Property Editor, goto the Line Properties tab, then I could select a line decoration.  This would then show a single line with an arrow at the end showing direction.
Where is this in ArcPro?  I found line properties and I see you can add effects, one being an arrow effect but I do not want a double line, just the arrow on the end.  Anyone know what effect that is or where I should be looking if it is not in the effects?
RonKnepper
I got it, they treat the markers as layers in the properties.  I guess easier but also completely different method for adding
JoshuaBixby
MVP Esteemed Contributor
There are several pre-defined arrow styles in the Gallery as well, which I find sometimes easier to use one of those and then modify it rather than modifying the default.
RonKnepper
Thanks, yeah I found those and then saw how it was handled in ArcPro.  Just takes a little getting used to when you have been using ArcGIS for a while.
