Getting Rest URL in QueryTask results
3523
10-13-2015 10:27 AM
SteveClark
I have a config file consisting of multiple rest endpoint urls and various where clauses. This allows the app to query for a value across multiple rest endpoints (can be 1 or as many as 10) with one or more fields (as many as 4).
I am putting the urls and where clauses in an array and then looping through each, firing off a QueryTask for each:
for (q = 0; q < layerIDs.length; q++) {
  var queryTask = new esriQueryTask(layerIDs);
  var query = new esriQuery();
  query.returnGeometry = true;
  query.outSpatialReference = {wkid:102100};
  query.outFields = [ '*' ];
  query.where = queryWheres;
  queryTask.execute(query, queryResults, queryError);
For the results, I am getting the results.features.geometry and throwing the graphics on the map. All this works well
var selections = results.features;
  array.forEach(selections, function(feat) {
  feat.setSymbol(new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 32, null, new Color([175,0,0,0.50])));
  map.graphics.add(feat);
if (selections.length == 0) {
  smess.set("value", "No results found for the query.");
} else if (selections.length == 1 && selections[0].geometry.type == "point") {
  map.centerAndZoom( selections[0].geometry, 20);
} else {
  var extent = GraphicsUtils.graphicsExtent(selections);
  map.setExtent(extent.expand(1.25));
However, if the results return more than one feature, I put the attributes in a ContentPane within a Container (Tab or Accordion). This I can do but I need to have the title for ContentPane to be something intelligent - preferably the mapserver name. I can use results.displayFieldName but that's nothing useful. I don't see anything in results beyond attributes and geometry.
var resPane = new ContentPane({
  title: ???results.displayFieldName??? + " (" + results.features.length + ")",
  content: grid
Is there a way (without running each QueryTask in a promise and having to hardcode each result) that I can get more information in the results from its QueryTask?
RobertScheitlin__GISP
Steve,
   Sure all you need to do is to pass the url in your execute.
queryTask.execute(query, queryResults, queryError, queryTask.url);
function queryResults(url, results) {
   console.info(url);
Steve,
   console.info(url);
SteveClark
Thank you, Robert. I'm just getting into this world and had not known you could pass other parameters. Using an example you stated elsewhere, I came up with this:
queryTask.execute(query, lang.hitch(this, queryResults, layerNames), lang.hitch(this, queryError, queryTask.url));
