view list of users ArcSDE
5558
09-25-2015 07:02 AM
by Anonymous User
Not applicable
I'm running Server 10.3 SQL. This is my first instance of running a server. Is there a way to view my list of users I've added to ArcSDE other than clicking on a feature dataset>Privileges>Add??
Tags (1)
JacobBoyle
You can do it in SQL Server Manager Studio.
JacobBoyle
by Anonymous User
Not applicable
Thank you Jacob. I don't currently have access to that. IT is slowly giving me more privileges so I'm guessing that this will fall in that category.
George_Thompson
Esri Notable Contributor
Hi Tom,
You can also use some SQL in SQL Server Management Studio (SSMS):
SELECT * FROM sys.database_principals
http://stackoverflow.com/questions/18866881/how-to-get-the-list-of-all-database-users
Here is a link to a site that will list all permissions for all users in a database (in SQL):
http://stackoverflow.com/questions/7048839/sql-server-query-to-find-all-permissions-access-for-all-u...
SELECT
    [UserName] = CASE princ.[type]
                    WHEN 'S' THEN princ.[name]
                    WHEN 'U' THEN ulogin.[name] COLLATE Latin1_General_CI_AI
                 END,
    [UserType] = CASE princ.[type]
                    WHEN 'S' THEN 'SQL User'
                    WHEN 'U' THEN 'Windows User'
                 END,
    [DatabaseUserName] = princ.[name],
    [Role] = null,
    [PermissionType] = perm.[permission_name],
    [PermissionState] = perm.[state_desc],
    [ObjectType] = obj.type_desc,--perm.[class_desc],
    [ObjectName] = OBJECT_NAME(perm.major_id),
    [ColumnName] = col.[name]
FROM
    --database user
    sys.database_principals princ
LEFT JOIN
    --Login accounts
    sys.login_token ulogin on princ.[sid] = ulogin.[sid]
LEFT JOIN
    --Permissions
    sys.database_permissions perm ON perm.[grantee_principal_id] = princ.[principal_id]
LEFT JOIN
    --Table columns
    sys.columns col ON col.[object_id] = perm.major_id
                    AND col.[column_id] = perm.[minor_id]
LEFT JOIN
    sys.objects obj ON perm.[major_id] = obj.[object_id]
WHERE
    princ.[type] in ('S','U')
UNION
--List all access provisioned to a sql user or windows user/group through a database or application role
SELECT
    [UserName] = CASE memberprinc.[type]
                    WHEN 'S' THEN memberprinc.[name]
                 END,
    [UserType] = CASE memberprinc.[type]
                 END,
    [DatabaseUserName] = memberprinc.[name],
    [Role] = roleprinc.[name],
FROM
    --Role/member associations
    sys.database_role_members members
JOIN
    --Roles
    sys.database_principals roleprinc ON roleprinc.[principal_id] = members.[role_principal_id]
JOIN
    --Role members (database users)
    sys.database_principals memberprinc ON memberprinc.[principal_id] = members.[member_principal_id]
LEFT JOIN
    --Login accounts
    sys.login_token ulogin on memberprinc.[sid] = ulogin.[sid]
LEFT JOIN
    --Permissions
    sys.database_permissions perm ON perm.[grantee_principal_id] = roleprinc.[principal_id]
LEFT JOIN
    --Table columns
    sys.columns col on col.[object_id] = perm.major_id
LEFT JOIN
UNION
--List all access provisioned to the public role, which everyone gets by default
SELECT
    [UserName] = '{All Users}',
    [UserType] = '{All Users}',
    [DatabaseUserName] = '{All Users}',
FROM
    --Roles
LEFT JOIN
    --Role permissions
LEFT JOIN
    --Table columns
JOIN
    --All objects
    sys.objects obj ON obj.[object_id] = perm.[major_id]
WHERE
    --Only roles
    roleprinc.[type] = 'R' AND
    --Only public role
    roleprinc.[name] = 'public' AND
    --Only objects of ours, not the MS objects
    obj.is_ms_shipped = 0
ORDER BY
    princ.[Name],
    col.[name],
    perm.[state_desc],
    obj.type_desc--perm.[class_desc]
Hope some of this helps.....
-George
GeodatabaseEnterprise GISManaging Data
--- George T.
by Anonymous User
Not applicable
Thanks George. I will give that a try once I get access from my IT
