I'm running Server 10.3 SQL. This is my first instance of running a server. Is there a way to view my list of users I've added to ArcSDE other than clicking on a feature dataset>Privileges>Add??
You can do it in SQL Server Manager Studio.
Hi Tom,
You can also use some SQL in SQL Server Management Studio (SSMS):
SELECT * FROM sys.database_principals
http://stackoverflow.com/questions/18866881/how-to-get-the-list-of-all-database-users
Here is a link to a site that will list all permissions for all users in a database (in SQL):
http://stackoverflow.com/questions/7048839/sql-server-query-to-find-all-permissions-access-for-all-users-in-a-database
SELECT [UserName] = CASE princ.[type] WHEN 'S' THEN princ.[name] WHEN 'U' THEN ulogin.[name] COLLATE Latin1_General_CI_AI END, [UserType] = CASE princ.[type] WHEN 'S' THEN 'SQL User' WHEN 'U' THEN 'Windows User' END, [DatabaseUserName] = princ.[name], [Role] = null, [PermissionType] = perm.[permission_name], [PermissionState] = perm.[state_desc], [ObjectType] = obj.type_desc,--perm.[class_desc], [ObjectName] = OBJECT_NAME(perm.major_id), [ColumnName] = col.[name] FROM --database user sys.database_principals princ LEFT JOIN --Login accounts sys.login_token ulogin on princ.[sid] = ulogin.[sid] LEFT JOIN --Permissions sys.database_permissions perm ON perm.[grantee_principal_id] = princ.[principal_id] LEFT JOIN --Table columns sys.columns col ON col.[object_id] = perm.major_id AND col.[column_id] = perm.[minor_id] LEFT JOIN sys.objects obj ON perm.[major_id] = obj.[object_id] WHERE princ.[type] in ('S','U') UNION --List all access provisioned to a sql user or windows user/group through a database or application role SELECT [UserName] = CASE memberprinc.[type] WHEN 'S' THEN memberprinc.[name] WHEN 'U' THEN ulogin.[name] COLLATE Latin1_General_CI_AI END, [UserType] = CASE memberprinc.[type] WHEN 'S' THEN 'SQL User' WHEN 'U' THEN 'Windows User' END, [DatabaseUserName] = memberprinc.[name], [Role] = roleprinc.[name], [PermissionType] = perm.[permission_name], [PermissionState] = perm.[state_desc], [ObjectType] = obj.type_desc,--perm.[class_desc], [ObjectName] = OBJECT_NAME(perm.major_id), [ColumnName] = col.[name] FROM --Role/member associations sys.database_role_members members JOIN --Roles sys.database_principals roleprinc ON roleprinc.[principal_id] = members.[role_principal_id] JOIN --Role members (database users) sys.database_principals memberprinc ON memberprinc.[principal_id] = members.[member_principal_id] LEFT JOIN --Login accounts sys.login_token ulogin on memberprinc.[sid] = ulogin.[sid] LEFT JOIN --Permissions sys.database_permissions perm ON perm.[grantee_principal_id] = roleprinc.[principal_id] LEFT JOIN --Table columns sys.columns col on col.[object_id] = perm.major_id AND col.[column_id] = perm.[minor_id] LEFT JOIN sys.objects obj ON perm.[major_id] = obj.[object_id] UNION --List all access provisioned to the public role, which everyone gets by default SELECT [UserName] = '{All Users}', [UserType] = '{All Users}', [DatabaseUserName] = '{All Users}', [Role] = roleprinc.[name], [PermissionType] = perm.[permission_name], [PermissionState] = perm.[state_desc], [ObjectType] = obj.type_desc,--perm.[class_desc], [ObjectName] = OBJECT_NAME(perm.major_id), [ColumnName] = col.[name] FROM --Roles sys.database_principals roleprinc LEFT JOIN --Role permissions sys.database_permissions perm ON perm.[grantee_principal_id] = roleprinc.[principal_id] LEFT JOIN --Table columns sys.columns col on col.[object_id] = perm.major_id AND col.[column_id] = perm.[minor_id] JOIN --All objects sys.objects obj ON obj.[object_id] = perm.[major_id] WHERE --Only roles roleprinc.[type] = 'R' AND --Only public role roleprinc.[name] = 'public' AND --Only objects of ours, not the MS objects obj.is_ms_shipped = 0 ORDER BY princ.[Name], OBJECT_NAME(perm.major_id), col.[name], perm.[permission_name], perm.[state_desc], obj.type_desc--perm.[class_desc]
Hope some of this helps.....
-George
Geodatabase Enterprise GIS Managing Data
Thank you Jacob. I don't currently have access to that. IT is slowly giving me more privileges so I'm guessing that this will fall in that category.
Thanks George. I will give that a try once I get access from my IT
Signed in members can post, follow updates, and more. New here? Register a free account.
