Map click event not firing on android when using dojox.mobile.View
8020
13
09-24-2015 10:22 AM
BillDaigle
I am trying to use the dojox.mobile framework to build a mobile friendly app.  However, as soon as I add a require for "dojox/mobile/View", the map stops registering click events reliably on Android devices.  It seems like it is an API issue, because if I roll back to API 3.10, it works fine.
Here is a jsFiddle that demonstrates the problem: http://jsfiddle.net/f1wt0yjq/
In order to see the problem on a desktop, you will need to view it in Android device using Chromes developer tools.  When you click the map using an IOS device or windows, you get a "map clicked" in the console.  The same is not when using an android device.
BillDaigle
Alright.  Finally got it working.  The key is setting window.document.dojoClick to false.
Here is a jsfiddle that seems to work on all emulated devices.
http://jsfiddle.net/8m8y6gea/8/
ChrisSmith7
Honored Contributor
Bill,
I tried this on my end and could see the clicks registered in console when targeting 3.14 and emulating a Samsung Galaxy S4.
RickeyFight
Using Chrome developer tools I emulated every type of touch device and it does not work.
ChrisSmith7
Honored Contributor
UA spoofing issue on my end. Reloaded and it no longer works.
BillDaigle
Are you refreshing the browser when you switch devices?  That is required on my end. If I do so, it works in the Apple devices, but not the Samsung or Google Nexus devices.
RickeyFight
Ok, So when I refresh the page the only one that does not work is the Laptop with touch.
I get these errors
ChrisSmith7
Honored Contributor
I noticed there are some console errors only present when emulating:
Also, I was able to get 2 map clicks, randomly, but could not muster more.
ChrisSmith7
Honored Contributor
And those console errors just look related to jsfiddle... Actually, interesting comment in action.js:
// TODO: refactor
// TODO: This code is now legacy code, none of it will make its way into Beta
BillDaigle
I noticed the errors when emulating as well.  I'm not too concerned about them since they are the same for both apple and android.
The problem is intermittent.  Once in a while I can get a event to fire, but rarely.  You can view the app I'm working on at this link: Sunrise/Sunset Times by Zone
It works fine on my desktop and on IOS devices, but not on Android.
RickeyFight
Bill,
I have no device besides emulators to try your app at. My dept has only IOS devices, Sorry.
I did get it to work emulated on a desktop as Samsung Galaxy note II.
