Map click event not firing on android when using dojox.mobile.View
8092
13
09-24-2015 10:22 AM
BillDaigle
I am trying to use the dojox.mobile framework to build a mobile friendly app.  However, as soon as I add a require for "dojox/mobile/View", the map stops registering click events reliably on Android devices.  It seems like it is an API issue, because if I roll back to API 3.10, it works fine.
Here is a jsFiddle that demonstrates the problem: http://jsfiddle.net/f1wt0yjq/
In order to see the problem on a desktop, you will need to view it in Android device using Chromes developer tools.  When you click the map using an IOS device or windows, you get a "map clicked" in the console.  The same is not when using an android device.
ChrisSmith7
Honored Contributor
Bill,
I got it to work setting my own event:
Edit fiddle - JSFiddle
BillDaigle
I like the concept, but it seems like a slippery slope when it comes to implementation.  I need it to behave like a map or feature layer click event. I would need to fetch the underlying graphics and code for the difference between a short click, long click, pan, etc.  Doable, but a potential maintenance nightmare.  I'm curious why this stopped working at version 3.11.  There was a move to Dojo 1.10 at this point.  I doesn't look like there is any functional difference between the the 1.9 and 1.10 version of dojo.mobile.View, so I suspect the issue is in the Javascript API.
I guess I'm leaning towards rolling back to version JSAPI 3.10 or trying a different mobile framework.
BillDaigle
Ok, I think I tracked it down to the root of the problem.  It appears to be caused by the following lines of code in "dojox/mobile/common", which is called by "dojox/mobile/View".
    // tell dojo/touch to generate synthetic clicks immediately
    // and regardless of preventDefault() calls on touch events
    win.doc.dojoClick = true;
    /// ... but let user disable this by removing dojoClick from the document
    if(has("touch")){
        // Do we need to send synthetic clicks when preventDefault() is called on touch events?
        // This is normally true on anything except Android 4.1+ and IE10+, but users reported
        // exceptions like Galaxy Note 2. So let's use a has("clicks-prevented") flag, and let
        // applications override it through data-dojo-config="has:{'clicks-prevented':true}" if needed.
        has.add("clicks-prevented", !(has("android") >= 4.1 || (has("ie") === 10) || (!has("ie") && has("trident") > 6)));
        if(has("clicks-prevented")){
            dm._sendClick = function(target, e){
                // dojo/touch will send a click if dojoClick is set, so don't do it again.
                for(var node = target; node; node = node.parentNode){
                    if(node.dojoClick){
                        return;
                var ev = win.doc.createEvent("MouseEvents");
                ev.initMouseEvent("click", true, true, win.global, 1, e.screenX, e.screenY, e.clientX, e.clientY);
                target.dispatchEvent(ev);
Looks like I might be able to override it for the map or feature layer.  Or maybe the whole page.  Not sure.
BillDaigle
Alright.  Finally got it working.  The key is setting window.document.dojoClick to false.
Here is a jsfiddle that seems to work on all emulated devices.
http://jsfiddle.net/8m8y6gea/8/
