Geoprocessing (intersecting / reading attributes / routing) with Javascript API
3592
5
09-23-2015 10:51 AM
wcESRI
I am attempting to work with the Javscript API do the following.
Enter an address (address 1), intersect a polygon, get an address (address 2) from that polygon and route a line between the resulting points.
I am trying to find the proper functionality in the API to support this processing.
I found the routing support in the sample on the directions app at Directions | ArcGIS API for JavaScript.
There is also an example for point in polygon search at Geoprocessing - Point in polygon search | ArcGIS API for JavaScript .  Is there an basic example of this functionality available?
Does anyone have any example of reading attributes from a selected feature?
Thanks for your time!
RobertScheitlin__GISP
Christopher,
   I would just use a simple QueryTask to get the intersection of Address 1 geocode point with your polygon layer. The returned results of the QueryTask will have the attributes that you can read.
QueryTask | API Reference | ArcGIS API for JavaScript
wcESRI
Robert, thanks for your help.
I am having difficulty with determining what classes to use and getting the results from the event.
I am trying to  use a search object and get the data from the search results.  I would then perform an intersection on the polygon layer and get the address.
I am trying to use a each object with no luck.  Am I using the right classes and how do I get the results from the event?
            var mySearch = new Search(
                map: myMap
            }, "searchDiv");
            mySearch.startup();
            //begin event handler
            mySearch.on("search-results", function(e)
                alert(e.results[0].toString());
            });   //end call process results function);  //end event handler
Christopher,
  Try using:
mySearch.on("select-result", function (evt){
  //Do something with the result feature
  console.info(evt.result.feature);
wcESRI
Robert,  thank you again.  However, your code issues an error in javascript.
My code is below.
       console.info(e.result.feature);
TypeError: Unable to get property 'feature' of undefined or null reference TypeError: Unable to get property 'feature' of undefined or null reference
The following code will produce a result but not very useful.
console.info(e.results[0].toString());
[object Object],[object Object],[object Object],[object Object],[object Object],[object Object]
I can't seem to access the event object in the seach results to get the results.
https://developers.arcgis.com/javascript/jsapi/search-amd.html#searchresults
Christopher,
  You need to look care fully at the API documentation the returned parameters for "select-result" is different than "select-result" code that I provided.
Search | API Reference | ArcGIS API for JavaScript | event-search-results
Your code would have to be:
     console.info(e.results);
     // This should return an array of results that have a extent and feature property
