How to add dgrid/OnDemandGrid inside a Dojo digit?
5827
6
09-22-2015 06:22 AM
DavidChrest
Does anybody know the trick to get a dgrid placed inside a dijit, such as a Tab Container or TitlePane?
This little code snippet did not work for me: | Dojo FAQ: Why doesn’t Dijit recognize my dgrid instances? | Blog | SitePen..
Any help would be greatly appreciated!
David
KenBuja
MVP Esteemed Contributor
In the application, the user can turn on layers and click on the visible features. For each layer turned on, a tab will be added to the TabContainer containing a dGrid of the returned features. You can see a version of this here
First, I create a TabContainer when initializing the application like this:
tc = new TabContainer({
    doLayout: false,
    style: { "width": "95%", "height": "100%" }
}, domConstruct.create("div"));
This is the code for building the Tabs from the results of an IdentifyTask
function buildTabContainer(results) {
    if (tc.hasChildren()) {
        tc.destroyDescendants();
    var combineResults = {};
    layerResultsGraphic.clear();
    for (var i = 0, len = results.length; i < len; i++) {
        var result = results;
        var feature = result;
        if (combineResults.hasOwnProperty(result.layerName)) {
            combineResults[result.layerName].push(result);
        } else {
            combineResults[result.layerName] = [result];
        switch (feature.geometry.type) {
            case "point": case "multipoint":
                layerResultsGraphic.add(new Graphic(feature.geometry, symbolResultPoint, feature.attributes));
                break;
            case "polyline":
                layerResultsGraphic.add(new Graphic(feature.geometry, symbolResultPolyline, feature.attributes));
                break;
            case "polygon": case "extent":
                layerResultsGraphic.add(new Graphic(feature.geometry, symbolResultPolygon, feature.attributes));
                break;
    for (var result in combineResults) {
        if (combineResults.hasOwnProperty(result)) {
            var columns = buildColumns(combineResults[result][0]);
            var features = [];
            for (i = 0, len = combineResults[result].length; i < len; i++) {
                features.push(combineResults[result]);
            var data = arrayUtils.map(features, function (feature) {
                return lang.clone(feature.attributes);
            var dataGrid = new (declare([Grid, Selection, DijitRegistry, ColumnHider]))({
                bufferRows: Infinity,
                columns: columns,
                selectionMode: "single",
                "class": "resultsGrid"
            var gridWidth = "width: " + String(columns.length * 100) + "px";
            dataGrid.addCssRule("#" + dataGrid.id, gridWidth);
            dataGrid.on("show", function () {
                dataGrid.resize();
            //dataGrid.on(mouseUtil.enterRow, gridEnter);
            dataGrid.on(mouseUtil.leaveRow, function () {
                map.graphics.clear();
            var plural = "";
            if (combineResults[result].length !== 1) { plural = "s"; }
            var cp = new ContentPane({
                content: combineResults[result].length + " feature" + plural,
                title: combineResults[result][0].layerName,
                style: "overflow: auto"
            }).placeAt(registry.byId("tabs"));
            cp.addChild(dataGrid);
            cp.startup();
            dataGrid.renderArray(data);
    tc.startup();
    tc.resize();
    return true;
TimWitt2
David,
in this example I placed it in the bottom pane, does that help?
Find Street Example - JSFiddle
Tim
DavidChrest
Your example shows  "dojox/grid/DataGrid", Im asking about "dgrid/OnDemandGrid".
TimWitt2
Ahh, I see! Sorry about that.
thejuskambi
I dont understand, why you are having problem with placing a dgrid inside a dijit. I have done it in couple of application. The main thing is to add it in the code and not through html tags.
you can just have a placeholder div in the html (template) and then create the grid during startup or create method. Check out the CMV framework.
KenBuja
    doLayout: false,
        } else {
                break;
            case "polyline":
                break;
                break;
            var features = [];
                columns: columns,
                dataGrid.resize();
            var plural = "";
            cp.startup();
    tc.startup();
    tc.resize();
    return true;
DavidChrest
Thanks so much Ken! Also, love your website! Very nice. Really helped inspire some ideas. Your explanation is the most straight-forward I've seen and I can understand it best. I'm a bit of a newbie so I was used to simply nesting dijits within dijits (like a set of RadioButtons inside a TitlePane).
David
