How to create widget group and drop down in header controller
9089
10
08-19-2015 10:44 AM
DanNorman
Has anyone figured out how to create widget groups as mentioned here: Controller widget—Web AppBuilder for ArcGIS | ArcGIS
i can not find to option to set a widget to "show in drop-down menu". The help file above makes it sound like a check box in the widget configuration accessible through the web app builder, without having to modify the code.
Thanks!
Don
RobertScheitlin__GISP
Donald,
   In the Header widget configuration just grab a widget that you want to group with another and drag and drop one on another. This creates a group.
Donald,
DanNorman
ha thanks, just made my next post right when you did! thank you for the reply!
haThach
Robert,
Do anyone know how to configure to show drop-down menu with the option of choosing a widget to be active instead of activating all the widgets in the groups?
CadeFurnas3
Hello. I have a few groups of widgets that I would like to display in a menu as in the image above. Here's the setting in the documentation:
Controller—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
So, groupSetting=dropDown needs to be added in the config.json, I think. Did you draw the image above, or is it from a real WAB app? If it's in a WAB app, we just need to look at the config.json file. I hope that helps.
EDIT: I see that you already saw that page in the docs. So we just need to figure out how to add it to the config.json. Lame.
feisishui
headercontroll widget  config.json 设置对应的要显示的groupsetting 为 dropDown,默认为openAll
AldwinGregorio
Hello guys. Is anyone having the same problem as mine? I already have my app, however, when I put the code below in the config.json of the Siderbar Controller, nothing happened. Am I doing it right? Thanks!
Aldwin,
 If you can not do this using the WAB ui then it is not supported for that theme.
AldwinGregorio
Got it! Thanks Robert!
I changed my theme, anyway.
DanNorman
within the widget panel of the Web app builder interface, click and drag on on top of the other.
