How to create widget group and drop down in header controller
9263
10
08-19-2015 10:44 AM
DanNorman
Has anyone figured out how to create widget groups as mentioned here: Controller widget—Web AppBuilder for ArcGIS | ArcGIS
i can not find to option to set a widget to "show in drop-down menu". The help file above makes it sound like a check box in the widget configuration accessible through the web app builder, without having to modify the code.
Thanks!
Don
DavidPfeiffer
I had to read through a few posts and esri docs to fully understand this.
Per ESRI:
Header Controller is associated with the Foldable theme while Sidebar Controller is associated with the Tab theme.
my config is located at: ..\configs\HeaderController\config_themes_FoldableTheme_widgets_HeaderController_Widget_1.json in my project.
Here is the json code:
"groupSetting": [
"label": "GROUP LABEL",
"type": "dropDown"
"type": "dropDown"
If you are unsure of the group label name, it should match the config located at ..\config.json
