Manually adding attachments
3999
08-04-2015 06:22 AM
JosephRogan
Good morning,
I am attempting to add attachments to my feature layer but have encountered a problem.  I have already successfully implemented code to view and delete existing attachments, and I thought my code was correct to add them, however the error callback function says: "Error: Access is denied."  My feature layer does have editing enabled, and other tools in my app work properly.  I do have the proxy thing working so I don't believe it is that either.  Any suggestions?
// Open the file dialog
dom.byId("inputAttachmentFile").click();
console.log(dom.byId("inputAttachmentFile").value);
featureLayer1.addAttachment(editingFeature.attributes["OBJECTID"], dom.byId("formAttachment"), function()
 // Update the info window's html
 dom.byId("buttonEditAttachment").innerHTML = "Delete";
 dom.byId("spanAttachmentLink").innerHTML = "[link]";
 console.log("Attachement added");
}, function (err)
 console.log(err);
BenGrod
Morning Joseph,
Has "Attachments" been enabled on the feature class? There are two different ways to enable attachments depending on where the feature resides. Below is a screen shot of enabling attachments for a feature which resides on ArcGIS Online. From the item details select the context menu under Layers and choose "Enable Attachments." The steps are a little different if in SDE and hosted on Portal. Hope this helps and good luck.
JosephRogan
Yes attachments are enabled.  The layer is published from my SDE.  When I test featureLayer1.hasAttachments it returns true.  Unfortunately I can't post the complete code for this site, it exists behind a firewall.  Unfortunately the AttachmentEditor widget does not meet my needs for this project either.
JosephRogan
I made a stripped down version of the site to test the attachment editor widget, and it worked.  This proves to me that there isn't a problem accessing the actual feature layer or the service.
I could potentially use the AttachmentEditor if I can get it to load in my custom info window (InfoTemplate).  I'm not sure how to get this working though.  I can get it to startup in a div (and appear in my popup), but to get the line attachmentEditor.showAttachments(graphic, featureLayer1); I don't know where I'm supposed to pull the graphic objects from.  It's not wired to an event the gives that object like in the code sample.
