"Pagination is not supported." Error
4813
05-13-2015 07:46 AM
ManjariGoyal
I wrote the javaScript to get the attribute table using Arcgis sample script but when I run it it gives an error "Pagination is not supported. I can see the points on the map but it's not pulling the attribute table. I am using arcgis 10.3. I am attaching the script and the output.
Please let me know how to fix this issue.
SteveCole
Honored Contributor
I don't know if this directly is the source of your issue but, based on this somewhat recent thread, pagination support is dictated by the underlying database.
ManjariGoyal
Steve, I looked in to it and I have SQL Server 2008. so will there be any way around to it.
SteveCole
Honored Contributor
Regretfully, I don't know this stuff but the thread I linked suggests that you may have to upgrade to SQL 2012 to support pagination. I hope someone else with more knowledge will chime in and add more to the discussion.
