Display the measurement of current segment in Measurement Widget?
4681
05-06-2015 12:55 PM
AnnCrystal
In this ESRI measurement widget sample
https://developers.arcgis.com/javascript/jssamples/widget_measurement.html​
when you draw a line, it dynamically displays the segment length. And, when you measure subsequent segments lengths, it add it to the previous length.
My question is: How can I add another result which dynamically shows the current segment length?
Any thoughts?
Thanks Ann
Tags (1)
PLadd
Here's how I figured out how to keep track of current segment length (I couldn't find any measurement properties that contained this value).  By keeping track of the "previous" total measurement, I can subtract it from the new total measurement to get the current segment length.  Perhaps there's an easier more concise approach.  Here's what I did:
//first create "global" variables at top of js
var segmentLength = 0; //used in measure tool to track last segment length
var PrevM = 0; //used in measure tool to track last total measurement
var Mtype = ''; //used to track measurement units for display
//then create a span under your measureDiv for displaying segment text
<span id="spanSegment" class="spanStyle"></span>
//create measure tool
measurement = new esri.dijit.Measurement({
                map: map,
                defaultLengthUnit: esri.units.FEET,
                _defaultLocationUnit: "esriDegreeMinuteSeconds"
            }, dojo.byId("measurementDiv"));
            measurement.startup();
//when I start measuring, be sure to zero out any previous values
//this could also be done when a measure tool is clicked
            measurement.on("measure-start", function (evt) {
                if (evt.geometry.type == "polyline") {
                    segmentLength = 0;
                    PrevM = 0;
                    dojo.byId("spanSegment").innerHTML = 'Segment Length: ' + segmentLength.toFixed(1) + ' ' + Mtype;
                else { dojo.byId("spanSegment").innerHTML = ''; }
            // as each segment is measured, collect values and show segment length
            measurement.on("measure", function (evt) {
                    var myVal = evt.values; //total measurement value
                    segmentLength = myVal - PrevM; //new segment value
                    PrevM = myVal; //remember current total measurement for next click
            //when done measuring, still need to show last segment, but then zero out values
            measurement.on("measure-end", function (evt) {
                    segmentLength = 0;
                    PrevM = 0
          //if user switches tools, say to area, then set segment text to empty to avoid confusion
          measurement.on("tool-change", function (evt) {
                dojo.byId("spanSegment").innerHTML = '';  //zero out current values
                Mtype = evt.unitName;
          //track if user changes unit for display purposes
            measurement.on("unit-change", function (evt) {
NOTE: I haven't figured out yet how to get perimeter values when measuring area.  I know you have to go to the root of the geometryServer values somehow but I'm struggling . . . .
TimWitt2
Hey Ann,
check out my draw tool, which includes what you need. Advanced Draw
Just check "Add Measurement" and you will see the total length and segment length.
Tim
