Collector shuts down on ipad ios 10.3 when I submit a location. has to be restarted.
16425
43
03-11-2015 09:21 AM
JeffersonJacobs
When I collect a point and hit submit, it saves it to the device, but then closes collector.  I have to re-open collector and re-open the map to collect each new point.
any suggestions?
Tags (1)
RussRoberts
Esri Notable Contributor
Can you share your map and service with Collector4ArcGIS and i'll check it out.
Russ
RickChubb
OK, I just sent you an invitation to our group. The map is called AGM Trapping Demo.
RussRoberts
Thanks Rick, I can reproduce your issue and we are looking into it. Please keep the map and service up while we are looking into the issue.
Thanks!
Russ
RickChubb
Will do. Thank you for the help!
RickChubb
Russ,
My original feature layer and tile package were WGS84.  I created new versions using Web Mercator and now everything works well. Is that a known limitation for iOS 10.3?
I was able to use WGS84 layers with version 10.2.7 on iOS.  Also, my Android phone with 10.3 has no problem with the WGS84 layers.
Rick
RuiGe
by Esri Contributor
Hi, Rick,
Were you able to use Collector update with this offline map (AGM Trapping Demo)?
Rui
JeffersonJacobs
Hi Russ,
Cool thanks. I created a group:
Here is the Link
http://arcg.is/1BK4OfA
hopefully that works.
Jefferson
RussRoberts
Can you invite Collector4ArcGIS into that group, I cannot access it from the link provided.
Russ
JeffersonJacobs
of course, sorry to have skipped that step.
Thanks again,
Jefferson
