Get unique values in Select by Attributes different than data
4811
03-03-2015 01:01 PM
KristineMuma
I have an oracle dataset with a Double column set to scale of 8 (don't know why it is set that way). Values that I can see in the data are 0.1, 0.35, 0.4, 0.65.  When I do a select by attribute and use the "get unique values" button, there is no 0.1. Instead I see in the list 0.10000000000000001. Which is more than a scale of 8.  If I choose this as the value to select by there is nothing in the selection. If I manually type in 0.1 instead of using the Get Unique Values button then the selection works, and selects the elements I expect it to select.
What is going on here!  I need to figure this out and fix it. My first thought is to set up a domain to constrain entry (don't know why there wasn't one already) . So far everything I have tried hasn't changed anything. This weird number persists in the Select by Attributes dialog when using the get Unique Values button.  I have never seen this before.
Anyone seen this and know how to get rid of this odd value and replace it with the correct one?
JayantaPoddar
Hi Kristine,
This seems to be an issue with the Double and Float datatypes. Check the thread below:
Select by Attribute on Float values not returning any record
Jay
Think Location
JayantaPoddar
Hi Kristine,
Jay
Think Location
