Issues in visualizing coordinates of a point feature class
3662
03-02-2015 07:21 AM
AriannaNumi
Hi!
I am working on a georeferenced image and I created a new feature class in my database representing some points on the road.
I need to have a table with the point ID and the coordinates (northing and easting) for each point. I thought this was straightforward put into the attribute table of the class but it is not. If I rightclick on the points I can see their location in the Identify window: how can I visualize a table with them?
I know I am missing something, I have just started to use ArcMap.
Many thanks for your help,
Arianna
BrianCarson2
Arianna,
You can use the following geoprocessing tool to add coordinates to your attribute table.
http://resources.arcgis.com/en/help/main/10.2/index.html#//001700000032000000
Add XY Coordinates (Data Management)
Alternatively, you can also add an X and Y field to your attribute table, and calculate the geometry of the points by right clicking on the field header.
Brian
BrianCarson2
Arianna,
Brian
AriannaNumi
Thank you so much!
