Synchronize mosaic data set
5083
02-12-2015 07:59 AM
IgnacioGuerrero
I added rasters  a mosaic data set by using a wildcard filter on a folder  (example *abc*) to add a subset of the files. I added a new file to the folder that meets the filter criteria. When I synchronize, I gives and error "Completed crawling 0 data source items" and the mosaic dataset is not updated. If I do the same with no filter (i.e  loading all the files in the folder), synchronization works. Any ideas about what is going on?
Regards,
IG
JakeSkinner
Esri Esteemed Contributor
Hi Ignacio,
Try specifying a LIKE query within the Synchronize Mosaic Dataset tool.  For example, apply the same wildcard filter for the Name field.  Ex:
IgnacioGuerrero
Thank you Jake, I tried your suggestion but unfortunately it did not work. Note that the mosaic data set was created initially with a file filter  (*abc*). I was able to update the mosaic data set using "Add Rasters", the original filter criteria and selecting "EXCLUDE_DUPLICATES". This updated the mosaic data set with the new file (it meets the filter criteria). The end effect is the same that I expected from "Synchronize". Nevertheless, I am still interested in using Synchronize if I can make it work.
