Query widget - spatial filter and operational layer issue
11092
23
02-06-2015 08:58 AM
VenusScott
Using my local install of WAB I've configured the Query widget to select by Use spatial filter to limit the features, Only features touching a user defined area, and Add the result as operational layer.
I also want the user to be able to export the operational layer as a CSV. I haven't been able to get the operational layer to display nor do I have the option to export anything as CSV?
I do have the Attribute Table configured to Allow exporting to CSV.
Anyone else have this issue?
VenusScott
It appears I've encountered a known Bug . . .
BUG-000084819: When Web AppBuilder Query widget results are added to an operation layer to the web application, the resulting map layer is inconsistently added to the attribute table.
RobertScheitlin__GISP
Venus,
   You have to select some rows before the export to csv will be active.
You can click the "Select Records in All Pages" if you don't want to manually select each row.
VenusScott
I want to select the data in the operational layer, but it doesn't show in the attribute table?
Venus,
   I get a tab with *_QueryResult for the Query that I do...
VenusScott
Well now that's frustrating! I don't get the operational layer? I even created the same map on our AGOL account and get the same results . . . no operational layer? I guess it's time to contact ESRI. It's things like this that made me use the profile pictures I have . . . LOL!
VenusScott
Did you have to Open Attribute Table from the Layer List in order to see the data?
Or did it populate automatically?
It did it automatically
VenusScott
I only get it if I go to the Layer List and click the "Open Attribute Table" option? Thank you. You are always so helpful and responsive Robert. I appreciate it.
VenusScott
GaryBarden
I've encountered a bug (BUG-000086549) where the attribute table for the operational layer is completely empty when opened.
Very Frustrating!
