How do I dynamically define an output feature class using variables
4227
01-08-2015 09:15 AM
LauraBlackburn
I am creating code to loop through feature classes in a folder and run the fishnet process.  I am trying to define the output feature class so that it is a combination of the input feature class and the scale used.  Here's what I have so far....any help is greatly appreciated as this is all new to me.
# Import arcpy module
import arcpy, os, sys, traceback
# Set the necessary product code
import arceditor
import arcinfo
# set workspace path for block location
aDataPath = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysis2\\'
arcpy.env.workspace = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysis2\\'
# Set datapath for grid files
bDataPath = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysis2\\6K\\'
# Set Geoprocessing environments
arcpy.env.snapRaster = ""
# Create a list of cell sizes
scaleList = [6000, 4000, 3000, 2000, 1000, 500]
# Create a list of searching radii
radiusList = ["3000 Meters", "2000 Meters", "1500 Meters", "1000 Meters", "500 Meters"]
# Step 1 - loop through each block and do the following processes at all grid scales
try:
     # Create List of feature classes starting with 'B' - all the block layers
    fc_list = arcpy.ListFeatureClasses("B*")
    for fc in fc_list:
        # Process: Create Fishnet
        # Create a describe object from the feature class
        desc = arcpy.Describe(fc)
        for scale in scaleList:
            # Define Fishnet Output Name
            Output_Grid_Name =bDataPath + scale + fc
             tempEnvironment0 = arcpy.env.extent
            arcpy.env.extent = desc.extent.XMin, desc.extent.XMax, desc.extent.YMin, desc.extent.YMax
            arcpy.CreateFishnet_management(Output_Grid_Name, desc.extent.XMin desc.extent.YMin, desc.extent.Xmin desc.extentXMax, scale, scale, "0", "0", desc.extent.XMax desc.extent.YMax, "LABELS", fc, "POLYGON")
            arcpy.env.extent = tempEnvironment0
except:
