Old version of JavaScript API for download
5967
12-04-2014 08:01 AM
YuryTritenko
Hi. Do you know if I can download older versions of the JavaScript API? We have a couple of applications that use APIs versions 2.6 and 2.8, and we've lately have been experienced problems with getting the API content from the ESRI servers. We would like to deploy them locally to avoid this problem.
Thanks!
Tags (1)
AlexanderNohe1
Honored Contributor
Hello Yury Tritenko‌,
To download the Javascript API, go to the following link and log in with your ArcGIS Online Organization Credentials:
SDK Downloads | ArcGIS for Developers
After logging in, on the right hand side you will see Download for locally hosting with a version number and a drop down.  Clicking on the version number will activate the drop down allowing you to select the version you would like to download for local hosting.  See the below photo:
I hope this helps!
Alexander N.
YuryTritenko
Thank you!
Noah-Sager
Hi Yuri,
If you have a Support contract, you can log a Case and we could probably find a copy of the older versions of the JavaScript API for you.
-Noah
YuryTritenko
Thanks!
