Linear Referencing and M Values
3020
12-04-2014 08:56 AM
DanCameron
I had to manually build m values for hundreds of levees (in the downstream direction) and wondering if there is a way to check that I didn't miss any levees. Is there a way I can look-up a table with all the "M" values other than clicking on on each individual levee?
Ideally I would like to be able to use Field Calc to populate a new column with every segment's M value so I could see if there are any 0 values.
Any help or ideas would be much appreciated! Thank You!
RichardFairhurst
See this post and use my Monotonicity calculation to find routes that have M patterns other than always increasing.
