ArcGIS - How to add multiple states to existing map?
2401
12-01-2014 11:22 AM
kaiserislam
I am new to ARCGIS. Can someone show me how can I go about adding 2 states New Jersey and Delaware to the existing code? So that it displays along with New York.
Is there also a wild card option to add all the states?
<!DOCTYPE html>
<html>
  <head>
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
  on iOS devices-->
  <title>Class Breaks Renderer</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
  <style>
  html, body, #map{
  height: 100%;
  margin: 0;
  padding: 0;
  </style>
  <script src="http://js.arcgis.com/3.11/"></script>
  <script>
  //https://developers.arcgis.com/javascript/jssamples/renderer_class_breaks.html
  var map;
  require([
  "esri/map", "esri/layers/FeatureLayer",
  "esri/InfoTemplate", "esri/symbols/SimpleFillSymbol",
  "esri/renderers/ClassBreaksRenderer",
  "esri/Color", "dojo/dom-style", "dojo/domReady!"
  ], function(
  Map, FeatureLayer,
  InfoTemplate, SimpleFillSymbol,
  ClassBreaksRenderer,
  Color, domStyle
  map = new Map("map", {
  basemap: "streets",
  center: [-74.215, 42.382],
  zoom: 7,
  slider: false
  var symbol = new SimpleFillSymbol();
  symbol.setColor(new Color([150, 150, 150, 0.5]));
  // Add five breaks to the renderer.
  // If you have ESRI's ArcMap available, this can be a good way to determine break values.
  // You can also copy the RGB values from the color schemes ArcMap applies, or use colors
  // from a site like www.colorbrewer.org
  // alternatively, ArcGIS Server's generate renderer task could be used
  var renderer = new ClassBreaksRenderer(symbol, "POP07_SQMI");
  renderer.addBreak(0, 25, new SimpleFillSymbol().setColor(new Color([56, 168, 0, 0.5])));
  renderer.addBreak(25, 75, new SimpleFillSymbol().setColor(new Color([139, 209, 0, 0.5])));
  renderer.addBreak(75, 175, new SimpleFillSymbol().setColor(new Color([255, 255, 0, 0.5])));
  renderer.addBreak(175, 400, new SimpleFillSymbol().setColor(new Color([255, 128, 0, 0.5])));
  renderer.addBreak(400, Infinity, new SimpleFillSymbol().setColor(new Color([255, 0, 0, 0.5])));
  var infoTemplate = new InfoTemplate("${NAME}", "${*}");
  var featureLayer = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3", {
  mode: FeatureLayer.MODE_SNAPSHOT,
  outFields: ["*"],
  infoTemplate: infoTemplate
  featureLayer.setDefinitionExpression("STATE_NAME = 'New York'");
  featureLayer.setRenderer(renderer);
  map.addLayer(featureLayer);
  </script>
  </head>
  <body>
  <div id="map"></div>
  </body>
</html>
RobertScheitlin__GISP
Kaiser,
  If you look at the code there is this line that sets the definition expression for the FeatureLayer:
You need to adjust this line to add the other states you are interested in, or remove this line if you want all states.
Kaiser,
   By the way you will notice that I have moved your thread from the GeoNet Help space to the ArcGIS API for JavaScript‌ space. It is important to post questions in the correct spaces.
kaiserislam
Robert  Thank you. I was trying something like this but none worked
featureLayer.setDefinitionExpression("STATE_NAME = 'New York', 'New Jersey'");
featureLayer.setDefinitionExpression("STATE_NAME = 'New York'","STATE_NAME = 'New Jersey'");
featureLayer.setDefinitionExpression("STATE_NAME = 'New York'");; featureLayer.setDefinitionExpression("STATE_NAME = 'New Jersey'")
The first options render nothing , the second option rendered on new york ,  third option only NJ .
what is right way to add other states?
Also, If  I try to display for the whole of USA removing the featurelayer, defintion(
  1. featureLayer.setDefinitionExpression("STATE_NAME = 'New York'");  )
it only  displays half of the USA. screen grab attached below.argis-screengrab.jpg
Kaiser,
  OK, so you need some basic SQL syntax help then.
featureLayer.setDefinitionExpression("STATE_NAME IN( 'New York', 'New Jersey', 'Delaware')");
The reason that removing the DefinitionExpression does not work is you are likely reaching the Map Services max feature output.
