How to open a .adf file in ARCGIS?
16685
11-21-2014 04:31 AM
poulameechakraborty
i have downloaded global LU and LC map in ESRI format but i am not being able to open it in Arc Gis desktop
BruceHarold
Esri Frequent Contributor
The .adf files are components of a coverage, navigate the directory above the .adf files with the Catalog window in ArcGIS for Desktop to see the data.
poulameechakraborty
I nevigated the directory above the file, but it shows empty in the catalog
window
BruceHarold
Please check your data are intact, it should be in this structure:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
curtvprice
this file is probably in esri grid format. Be sure have both the dataset and info folders. Catalog will only recognize data that is in the proper structure to be read; to see what's actually in the folder you need to use Windows Explorer.
ArcGIS Help (10.2, 10.2.1, and 10.2.2): Esri Grid format
workspace_folder
     mygrid
       xxx.adf
       prj.adf
     info
       arc.dr9
       xxxx.dat
       xxxx.nit
