hello tim,
i found this code very useful,but in buffer parameters when i give distance 50 or 60 or 100 and draw the circle the radius is not changing can you please fix it.and secondly
--i want to use for loop, for featurelayers instead of featurelayer 1,featurelayer 2,featurelayer 3.(i have 30 layers) and please convert it in legacy module. thanks in advance tim.
the following code is running fine..
#rightPane {
#messages {
require([
| "dojo/parser", "esri/map", "esri/toolbars/draw", "dojo/promise/all", |
| "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", |
| "esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol", "esri/layers/FeatureLayer", |
| "esri/graphic", "esri/tasks/query", "esri/tasks/QueryTask", "esri/tasks/FindTask", "esri/tasks/FindParameters", "esri/InfoTemplate", |
| "dojo/_base/array", "esri/dijit/Legend", "dijit/form/Button", "esri/layers/ArcGISDynamicMapServiceLayer", |
| "esri/Color", "dojo/dom", "dojo/on", "esri/tasks/GeometryService", "esri/tasks/BufferParameters", |
| "dijit/registry", "dojo/dom-construct", "dijit/form/CheckBox", "esri/geometry/screenUtils", "esri/graphicsUtils", |
| "dijit/layout/BorderContainer", "dijit/layout/ContentPane", |
| "dijit/layout/AccordionContainer", "dojo/domReady!"], function ( |
parser, Map, Draw, All,
SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
PictureFillSymbol, CartographicLineSymbol, FeatureLayer,
Graphic, Query, QueryTask, FindTask, FindParameters, InfoTemplate,
arrayUtils, Legend, Button, ArcGISDynamicMapServiceLayer,
Color, dom, on, GeometryService, BufferParameters, registry,
domConstruct, CheckBox, screenUtils, graphicsUtils) {
| console.log(registry.byId("zoomin")); |
| registry.byId("search").on("click", doFind); |
| map = new Map("mapDiv", { |
| basemap: "streets", |
| center: [-85.82966, 33.666494], |
| zoom: 13 |
| map.on("load", initToolbar); |
| var markerSymbol = new SimpleMarkerSymbol(); |
| markerSymbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE); |
| markerSymbol.setSize(12); |
| markerSymbol.setColor(new Color([255,0,0,0.5])); |
| var fieldsSelectionSymbol = |
| new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, |
| new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, |
| new Color([255, 0, 0]), 1.5), new Color([255, 255, 0, 1.5])); | |
| var featureLayer1 = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0", { |
| mode: FeatureLayer.MODE_ONDEMAND, |
| infoTemplate: new InfoTemplate("Block: ${BLOCK}", "${*}"), |
| outFields: ["POP2000", "HOUSEHOLDS", "HSE_UNITS", "TRACT", "BLOCK"] |
| featureLayer1.setSelectionSymbol(markerSymbol); |
| featureLayer1.setVisibility(false); |
| featureLayer1.on("selection-clear", function() { |
| var featureLayer2 = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/1", { |
| infoTemplate: new InfoTemplate("Block Group: ${BLKGRP}", "${*}"), |
| outFields: ["POP2000", "HOUSEHOLDS", "HSE_UNITS", "TRACT", "BLKGRP"] |
| featureLayer2.setSelectionSymbol(markerSymbol); |
| featureLayer2.setVisibility(false); |
| featureLayer2.on("selection-clear", function() { |
| var featureLayer3 = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2", { |
| infoTemplate: new InfoTemplate("County Name: ${NAME}", "${*}"), |
| outFields: ["POP2000", "HOUSEHOLDS", "HSE_UNITS", "NAME"] |
| featureLayer3.setSelectionSymbol(fieldsSelectionSymbol); |
| featureLayer3.setVisibility(false); |
| featureLayer3.on("selection-clear", function () { |
| //add the legend |
| map.on("layers-add-result", function (evt) { |
| var layerInfo = arrayUtils.map(evt.layers, function (layer, index) { |
| return {layer:layer.layer, title:layer.layer.name}; |
| if (layerInfo.length > 0) { |
| var legendDijit = new Legend({ |
| map: map, |
| layerInfos: layerInfo |
| }, "legendDiv"); |
| legendDijit.startup(); |
| //add check boxes |
| arrayUtils.forEach(layerInfo, function (layer) { |
| var layerName = layer.title; |
| if (layerName == undefined) { |
| layerName = "feature"; |
| var checkBox = new CheckBox({ |
| name: "checkBox" + layer.layer.id, |
| value: layer.layer.id, |
| checked: layer.layer.visible, |
| onChange: function (evt) { |
| var clayer = map.getLayer(this.value); |
| clayer.setVisibility(!clayer.visible); |
| this.checked = clayer.visible; |
| //add the check box and label to the TOC |
| domConstruct.place(checkBox.domNode, "toggle", |
| "after"); |
| var checkLabel = domConstruct.create('label', { |
| 'for': checkBox.name, |
| innerHTML: layerName |
| }, checkBox.domNode, "after"); |
| domConstruct.place("<br/>", checkLabel, |
| "after"); |
| map.addLayers([featureLayer3, featureLayer2, featureLayer1]); |
| // lineSymbol used for freehand polyline, polyline and line. | |
| var lineSymbol = new CartographicLineSymbol( |
| CartographicLineSymbol.STYLE_SOLID, |
| new Color([255, 0, 0]), 10, |
| CartographicLineSymbol.CAP_ROUND, |
| CartographicLineSymbol.JOIN_MITER, 5); |
| // fill symbol used for extent, polygon and freehand polygon |
| var fillSymbol = new SimpleFillSymbol(); |
| function initToolbar() { |
| tb = new Draw(map); |
| tb.on("draw-end", addGraphic); |
| // event delegation so a click handler is not |
| // needed for each individual button |
| on(dom.byId("info"), "click", function (evt) { |
| if (evt.target.id === "info") { |
| return; |
| var tool = evt.target.id.toLowerCase(); |
| tb.activate(tool); |
on(dom.byId("clearSelectionButton"), "click", function () {
| featureLayer1.clearSelection(); |
| featureLayer2.clearSelection(); |
| featureLayer3.clearSelection(); |
| dom.byId("messages").innerHTML = "<a>No features selected</a>"; |
| function addGraphic(evt) { |
| //deactivate the toolbar and clear existing graphics | |
| map.enableMapNavigation(); |
| tb.deactivate(); |
| // figure out which symbol to use |
| var symbol; |
| if (evt.geometry.type === "point" || evt.geometry.type === "multipoint") { |
| symbol = markerSymbol; |
| } else if (evt.geometry.type === "line" || evt.geometry.type === "polyline") { |
| symbol = lineSymbol; |
| } else { |
| symbol = fillSymbol; |
| map.graphics.add(new Graphic(evt.geometry, symbol)); |
| queryMapService(evt.geometry); |
| function queryMapService(Geom) { |
| var promises = []; |
| var query = new Query(); |
| query.returnGeometry = false; |
| query.outFields = ["*"]; |
| query.geometry = Geom; |
| promises.push(featureLayer1.selectFeatures(query, FeatureLayer.SELECTION_NEW)); |
| promises.push(featureLayer2.selectFeatures(query, FeatureLayer.SELECTION_NEW)); |
| promises.push(featureLayer3.selectFeatures(query, FeatureLayer.SELECTION_NEW)); |
| var allPromises = new All(promises); |
| allPromises.then(function (r) { |
| showResults(r); |
| function showResults(results) { |
| var featureLayer1Message = results[0].length; |
| var featureLayer2Message = results[1].length; |
| var featureLayer3Message = results[2].length; |
| var count = 0; |
| for (var i = 0; i < results.length; i++) { |
| count = count + results.length; |
| dom.byId("messages").innerHTML = "Total features selected: <b>" + count + "</b><br> FeatureLayer1: <b>" + featureLayer1Message + "</b><br> FeatureLayer2: <b>" + featureLayer2Message + "</b><br> FeatureLayer3: " + featureLayer3Message; |
| //Create Find Task using the URL of the map service to search |
| findTask = new FindTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/"); |
| map.on("load", function () { |
| //Create the find parameters |
| findParams = new FindParameters(); |
| findParams.returnGeometry = true; |
| findParams.layerIds = [0, 1, 2]; |
| findParams.searchFields = ["POP2000", "HOUSEHOLDS", "HSE_UNITS", "NAME", "BLKGRP", "TRACT", "BLOCK"]; |
| findParams.outSpatialReference = map.spatialReference; |
| console.log("find sr: ", findParams.outSpatialReference); |
| function doFind() { |
| //Set the search text to the value in the box |
| findParams.searchText = dom.byId("jobNumber").value; |
| findTask.execute(findParams, showfndResults); |
| function showfndResults(findresults) { |
| //This function works with an array of FindResult that the task returns |
| var markerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 12, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1.5), new Color([255, 0, 0, 0.5])); |
| var polygonSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 0, 0, 0.5])); |
| //create array of attributes |
| var items = arrayUtils.map(findresults, function (result) { |
| var graphic = result.feature; |
| if(graphic.geometry.type == 'point'){ |
| graphic.setSymbol(markerSymbol);} |
| else{graphic.setSymbol(polygonSymbol);} |
| map.graphics.add(graphic); |
| return result.feature; |
| var myFeatureExtent = graphicsUtils.graphicsExtent(items); |
| map.setExtent(myFeatureExtent, true); |
| gsvc = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); |
| var params = new BufferParameters(); |
| params.distances = [ dom.byId("distance").value ]; |
| params.outSpatialReference = map.spatialReference; |
| params.unit = GeometryService[dom.byId("unit").value]; |
| if (geometry.type === "polygon") { |
| //if geometry is a polygon then simplify polygon. This will make the user drawn polygon topologically correct. |
| gsvc.simplify([geometry], function(geometries) { |
| params.geometries = geometries; |
| gsvc.buffer(params, showBuffer); |
| } else { |
| params.geometries = [geometry]; |
| function showBuffer(bufferedGeometries) { |
| var symbol = new SimpleFillSymbol( |
| new SimpleLineSymbol( |
| SimpleLineSymbol.STYLE_SOLID, |
| new Color([255,0,0,0.65]), 2 |
| new Color([255,0,0,0.35]) |
| array.forEach(bufferedGeometries, function(geometry) { |
| var graphic = new Graphic(geometry, symbol); |
| tb.deactivate(); |
| map.showZoomSlider(); |
| </script> |
| </head> |
| <body class='claro'> |
| <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;"> |
| <div id="mapDiv" class="shadow roundedCorners" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div> |
| <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'right'" class="roundedCorners" id="rightPane"> |
| <div data-dojo-type="dijit.layout.AccordionContainer"> |
| <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Graphics'" id='graphics'> |
| <div id="info"> |
| <span style="padding: 10px 0;">Click to toggle each layer on or off</span> |
| <div id="toggle" style="padding: 2px 2px;"></div> |
| <br /><hr /> |
| <div>Select a shape then draw on map to add graphic</div> |
| <button id="Point">Point</button> |
| <button id="Multipoint">Multipoint</button> |
| <button id="Line">Line</button> |
| <button id="Polyline">Polyline</button> |
| <button id="FreehandPolyline">Freehand Polyline</button> |
| <button id="Extent">Rectangle</button> |
| <button id="Circle">Circle</button> |
| <button id="Polygon">Polygon</button> |
| <button id="FreehandPolygon">Freehand Polygon</button> |
| <button id="clearSelectionButton" data-dojo-type="dijit/form/Button">Clear Selection</button> |
| | | | <button data-dojo-type="dijit.form.Button" type="button" onclick="map.graphics.clear();">Clear Graphics</button> |
| </div> |
| <br /><hr /> |
| <div><b>Buffer Parameters</b></div> |
| Distance: <input type="text" id="distance" size="3" value="" /> |
| <select id="unit" style="width:90px;"> |
| <option value="UNIT_STATUTE_MILE">Miles</option> |
| <option value="UNIT_FOOT">Feet</option> |
| <option value="UNIT_KILOMETER">Kilometers</option> |
| <option value="UNIT_METER">Meters</option> |
| </select><br /> |
| <br /><hr /> |
| | | | | | | <div>Search features a using keyword</div> |
| | | | | | | | <input type="text" id="jobNumber" size="20" value=""/> | |
| | | | | | | | <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Search</button> | | | | | | | | |
| | | | | | | | <br /><hr /> |
| | | | | | | | <div id="messages"></div> |
| </div> |
| <div data-dojo-type="dijit/layout/ContentPane" id="legendPane" data-dojo-props="title:'Legend'"> |
| <div id="legendDiv"></div> |
| </div> |
| </div> |
| </div> |
| </div> |
</body>
