Dear Community
When defining parameters in a .pyt (Python toolbox) I would like to make one of the parameters optional - I think.
It's a boolean parameter, allowing the user to specify weather the tool is allowed to overwrite certain values.
I have made it default to False, and that would be the correct setting in 9 of 10 cases, so I would prefer if the tool would be able to just go with this default value. Unfortunately, when run, the tool insist that I toggle the boolean, before it will remove the little green dot. If I run the tool with the default values untouched, it gives me an error-box saying: "ERROR 000735: Overwrite Existing OBJNAM and NOBJNM: Value is required"
I have tried to change the parameter from parameterType="Required", to parameterType="Optional", but it seems to have no effect on the tool behaviour.
I have decided to paste the entire code here, it's still 90% cut-and-paste from ArcGIS Help (10.2, 10.2.1, and 10.2.2) , ArcGIS Help (10.2, 10.2.1, and 10.2.2) , and others but I guess the error is in a combination of things, and not the isolated line.
I have marked the parameter (line 81), that I try to change to make a difference.
#------------------------------------------------------------- # Name: GNDBtoolbox.pyt # Purpose: A python-toolbox to work with the "Greenlandic Names Data Base" (GNDB) and NIS. # Author: Martin Hvidberg # e-mail: mahvi@gst.dk, Martin@Hvidberg.net # Created: 2014-09-16 # Copyright: CopyLeft # ArcGIS ver: 10.2.0 # Python ver: 2.7.3 #------------------------------------------------------------- import arcpy class Toolbox(object): def __init__(self): """Define the toolbox (the name of the toolbox is the name of the .pyt file).""" self.label = "The_GNDB_Toolbox" self.alias = "Toolbox to work with GNDB and NIS" self.description = "This is the description of the toolbox..." # List of tool classes associated with this toolbox self.tools = [GNDBruninTOC] class GNDBruninTOC(object): """ GNDB update NIS - assuming feature classes all ready opened in TOC Created on 27 Sep 2011 @author: mahvi@gst.dk / Martin@Hvidberg.net """ def __init__(self): """Define the tool (tool name is the name of the class).""" self.label = "GNDB_update_NIS_run_in_TOC" self.description = "This tool will update the selected NIS FC, which must be in the TOC" self.canRunInBackground = True # True = Obey "Background Processing setting" in the Geoprocessing Options dialog. def getParameterInfo(self): """Define parameter definitions""" # 0. The Feature layer to receive GNDB names param0 = arcpy.Parameter( displayName="Input Features", name="in_features", datatype="GPFeatureLayer", parameterType="Required", direction="Input") # 1. The point feature class holding the GNDB param1 = arcpy.Parameter( displayName="GNDB points", name="GNDB", datatype="GPFeatureLayer", parameterType="Required", direction="Input") param1.value = "NamesP" # 2. The Mode param2 = arcpy.Parameter( displayName="The Mode", name="Mode", datatype="GPString", parameterType="Required", direction="Input") param2.filter.type = "ValueList" param2.filter.list = ["Berit", "Test"] param2.value = param2.filter.list[0] # 3. Overwrite param3 = arcpy.Parameter( displayName="Overwrite Existing OBJNAM and NOBJNM", name="Overwrite", datatype="GPBoolean", parameterType="Optional", # <------ This seems to have no effect ? direction="Input") param3.value = "False" params = [param0, param1, param2, param3] return params def isLicensed(self): """Set whether tool is licensed to execute.""" return True def updateParameters(self, parameters): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" return def updateMessages(self, parameters): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return def execute(self, parameters, messages): """The source code of the tool.""" # put processing here ... return
Martin,
I created a new pyt with the code provided, and the parameter shows optional for me:
Have you refreshed the toolbox since you updated the code? Could you try copying it into a new pyt?
Timothy
