Format Info Window Content
2257
10
09-24-2014 08:07 AM
RichardMoussopo
I am trying to format the info window template and it is not working. here is my code below:
Also, is it possible to change the background color of the info window header through css?
var identify = new esri.tasks.IdentifyTask(".../MapServer");
        var identifyParams = new esri.tasks.IdentifyParameters();
        identifyParams.geometry = evt.mapPoint;
        identifyParams.mapExtent = map.extent;
        identifyParams.returnGeometry = true;
        identifyParams.tolerance = 3;
        map.infoWindow.clearFeatures();
        //Define a good infoTemplate
        var infoTemplateUtilities = new InfoTemplate();
        infoTemplateUtilities.setTitle("Facility: <b>${FACILITYID}</b>");
        infoTemplateUtilities.setContent("MAPREF NUMBER :  <b>${MAPREF}</b><br/>" +
                                  "<b>2007 density: </b>${POP07_SQMI:compare}<br/><br/>" +
                                  "<b>2000: </b>${POP2000:NumberFormat}<br/>" +
                                  "<b>2000 density: </b>${POP00_SQMI:NumberFormat}");
        try {
            identify.execute(identifyParams, function (results) {
                map.infoWindow.setFeatures(dojo.map(results, function (result) {
                    var feature = result.feature;
                    feature.infoTemplate.setInfoTemplate(infoTemplateUtilities); //<======  This method here does not work at all...
                    //feature.setInfoTemplate(new esri.InfoTemplate());  //<======  This method here works fine...
                    return feature;
                map.infoWindow.show(evt.mapPoint);
        catch (ex) {
            alert(ex.toString());
ScottRutzmoser2
Hi Richard,
Two things to check
1) do you require esri/InfoTemplate
2) on line 12 above         var infoTemplateUtilities = new InfoTemplate();
I think you should define it like         var infoTemplateUtilities = new esri.InfoTemplate()
RiyasDeen
Hi Richard,
feature.setInfoTemplate(infoTemplateUtilities); should work.
for changing the backgrounf color use
.esriPopup .titlePane{
background-color: #ffffff
RichardMoussopo
Thank you Riyas, the css worked but the info template did not. I am not sure why the Info Window is not showing up when I use feature.setInfoTemplate(infoTemplateUtilities);
It does work when I use   feature.setInfoTemplate(new esri.InfoTemplate());
RichardMoussopo
I am also wondering if the number of fields to show could be the issue?
because when using the default method feature.setInfoTemplate(new esri.InfoTemplate());
it shows all the fields in the info window.
RiyasDeen
Hi Richard,
Have you got fields POP07_SQMI, POP2000, POP00_SQMI in your layer. can you post a screenshot of your infowindow output?
RichardMoussopo
here is the infoTemplate I want to use:
                                  "<b>Install Date: </b>${INSTALLDATE}<br/><br/>" +
                                  "<b>Material: </b>${MATERIAL}<br/>" +
                                  "<b>Diameter: </b>${DIAMETER}");
        try {
                    return feature;
        catch (ex) {
and here is the Default info Template
BenFousek
The method set setInfoTemplate() belongs to the feature (graphic) not the feature's infoTemplate object.
The popup is fully customizable w/ css. Look it up with dev tools. It's a div in the map dom node w/ base class "esriPopup".
RichardMoussopo
Thank you Ben,
still did not work.
ScottRutzmoser2
Hi Richard,
Two things to check
BenFousek
Richard,
Scott's right. Looks like you're using legacy. Consider switching to AMD.
