Format Info Window Content
3542
10
09-24-2014 08:07 AM
RichardMoussopo
I am trying to format the info window template and it is not working. here is my code below:
Also, is it possible to change the background color of the info window header through css?
var identify = new esri.tasks.IdentifyTask(".../MapServer");
        var identifyParams = new esri.tasks.IdentifyParameters();
        identifyParams.geometry = evt.mapPoint;
        identifyParams.mapExtent = map.extent;
        identifyParams.returnGeometry = true;
        identifyParams.tolerance = 3;
        map.infoWindow.clearFeatures();
        //Define a good infoTemplate
        var infoTemplateUtilities = new InfoTemplate();
        infoTemplateUtilities.setTitle("Facility: <b>${FACILITYID}</b>");
        infoTemplateUtilities.setContent("MAPREF NUMBER :  <b>${MAPREF}</b><br/>" +
                                  "<b>2007 density: </b>${POP07_SQMI:compare}<br/><br/>" +
                                  "<b>2000: </b>${POP2000:NumberFormat}<br/>" +
                                  "<b>2000 density: </b>${POP00_SQMI:NumberFormat}");
        try {
            identify.execute(identifyParams, function (results) {
                map.infoWindow.setFeatures(dojo.map(results, function (result) {
                    var feature = result.feature;
                    feature.infoTemplate.setInfoTemplate(infoTemplateUtilities); //<======  This method here does not work at all...
                    //feature.setInfoTemplate(new esri.InfoTemplate());  //<======  This method here works fine...
                    return feature;
                map.infoWindow.show(evt.mapPoint);
        catch (ex) {
            alert(ex.toString());
RichardMoussopo
Thank you all,
the problem was the legacy.
changed to var infoTemplateUtilities = new esri.InfoTemplate(); and it worked.
