Fail to renew expired 10.1 SDE
650
03-01-2013 06:33 AM
by Anonymous User
Not applicable
Original User: wilsonl
Hi All,
Our 10.1 ArcGIS license just expired yesterday. I can successfully re-authorize/renew the Server part but not the SDE.
When I connect to the SDE in ArcCatalog, it asked for a  EPC file. Then I point to the new keycodes file that I copied from the arcgis server machine (\\Program Files\ESRI\License10.1\sysgen) and I got �??Fail to connect to database. Invalid parameter�?� message.
Did I miss anything? Can you please help?
thanks a lot!!!
Wilson
[ATTACH=CONFIG]22298[/ATTACH][ATTACH=CONFIG]22299[/ATTACH]
by Anonymous User
Not applicable
Original User: asrujit
Wilson,
You can download a fresh ECP file separately from the below link and use that for the authorization:
https://customers.esri.com/index.cfm?event=pub.ecpAuthorizations
You can open the Keycode file that you are using to authorize (use a notepad) and check whether the licenses are updated there.
Though, I would suggest calling ESRI Tech Support for proper assistance.
Regards,
WilsonLee
Wilson,
Regards,
Thanks, just generated a fresh epc and it's still not working : (
WilsonLee
do i need to re-enable the sde via the tool in arc toolbox?
WilsonLee
just figured it out. need to run sdesetup command
thanks all
