Defining a Composite in 10.0 your Search Fields Don't Match?
517
03-01-2013 08:17 AM
DEWright_CA
I am trying to automate the creation/update of several geocoders into Composites and have a couple things that are not nice that I wonder if anyone has worked out.
  • In the Locator XML file, you can define you want the X/Y values written, but when setting a composite to use several locators that have this setting defined it doesn't carry them through.
  • In the Locator XML file, you can define alternate field names to trigger on, but when setting a composite to use several locators that have this setting defined it doesn't carry them through forcing you to go through and manually enter these all over again.
Is there a place where you can define Presets for the new Composite Locator build process to address these? For me moving to 10.1 isn't a option since so much was changed on the Server and ArcObjects level we need more time to migrate.
Suggestions???
