Raster Rotate error, as well in Spline with Barriers
1089
03-01-2013 12:57 AM
justinanainyte
While running batchscript 'Spine with Barriers' on Arcgis 9.3 at the last step the script fails giving a Raster Rotate Error of '9999', so no futher information available.
I have separately tried to simply rotate raster and get the same type of error, the undefined one. No information writen in the history file, as well as nothing is limited by administrator or so.
Is there some explanation or way I can solve this problem?
SteveLynch
Justina
I'm sorry to hear that you are experiencing problems.
Please try the following:
- use Spatial Analyst IDW with the points that you are using in SplineWithBarriers
- use the same field and cell size and output raster name
Does this work?
If it does then try SplineWithBarriers with a barrier.
Or zip and email ([email protected]) me your dataset, the field you're using and the cell size.
Regards
Steve
