Print secure services
1863
6
11-02-2012 04:13 AM
by Anonymous User
Not applicable
Original User: ER_JAS
Hi
I've made a copy of the Export Web Map tool and set a arcgis server connection
[ATTACH=CONFIG]18968[/ATTACH]
The user for this connection is added to the role at the server and can access the secure services.
[ATTACH=CONFIG]18969[/ATTACH]
When i use my custom print service i get an execution failed.
The server log says:
Error executing tool.: Layer "Kabel": Failed to create layer from service at (and a complete list of my secure layers)
When i remove the secure layers the print task completes and shows the basemap just fine in a pdf.
What is wrong?
ZacharyHart
Honored Contributor
Hi, is this relevant to what you're trying to do?
Click the plus (+) button and browse to the GIS server connection containing the secured services you will print.
The connection needs to have the name and password saved within it. It should be a user connection, not a publisher or administrative connection.
http://resources.arcgis.com/en/help/main/10.1/index.html#//0154000005q3000000
by Anonymous User
Not applicable
Hi LANDVEST
thanks for the reply.
That's exactly what i have done, but i still can't print my secure services
RandallWilliams
Hi Jacob,
1. I'm assuming you're working with 10.1, is that correct?
2. It also looks like you're authenticating using a Windows user, is that also correct?
3. Do you have authentication defined at the GIS tier or at the Web Tier, and do you use tokens?
by Anonymous User
Not applicable
Hi Randall
Yes im using 10.1, and windows Security, authentication defined at the Web tier, and im not using tokens
regards
Jacob
VickyS
Did you manage to solve this. I have exactly the same problem and setup.
Thank you
by Anonymous User
Not applicable
Yes i did, i ended up adding the user defined in the print service to the admin role on my AGS (the user was in a role with user privileges before)
