Jamal,
The tool is included in the Infrastructure Editing Template. The template include an add in that contains this functionality as well as a secondary trace, a sewer profile graph trace and much much more.
You can find the released version here
http://www.arcgis.com/home/item.html?id=14bdfb26bc2f4e0388a633fbd0ccca02
And the most recent beta version here
http://forums.arcgis.com/threads/20000-Beta-Versions?p=116013&viewfull=1#post116013
Jamal,
Jamal,
Jamal,
The toolbar in the video is an order version and it has changed since the filming. The tool allows you to click a location on the main and preform the trace. So select the Tool and just click on the main. If you want to return all the features as a selection set, hold the control key down when you click on the main. Where you able to get the tools to work on the sample data? Did you get an error about a source not being defined? If so, you need to connect a water source to the network(wNetworkStructure). Find one of these features and connect it to a water main with a new water main. There was a problem with the sample data that is going to be fixed in the release this week.
You need to update the configuration file to allow the tool to work on your own data. If you download the most recent version from the Beta thread, there is a tool to open the configuration file you. You will need to update the Trace Isolation tags, these tags let you define the Sources of water and the Valves, as well as their fields and values that define if they are operable or non operable. I would review the overview pdfs that are also available on the beta thread.
Jamal,
Please download and try this version. Make sure to uninstall the older version first.
http://downloads.esri.com/blogs/waterutilities/BetaVersions/release11-1-2011.zip
