How to add an attribute value to info window as a link?
3214
08-22-2014 01:59 AM
HabG_
Hi, I am using ArcGIS API for JavaScript and I want to use a value from a feature class attribute as a hyperlink.
For example, "template.setContent("<b>Web Address: <a target='_blank' href=http://www.esri.com>${Web_Address}</a></b>");
This creates an info window with "Web Address" link to ESRI's website.
The web addresses for my features (about 950 features of a polygon features class) are included in the "Link" field. How do I write the code similar to the above example but the link in my info window to point the the attribute record in my "Link" field?
RiyasDeen
below should do it.
template.setContent("<a target='_blank' href=${Web_Address}>Link</a>");
RiyasDeen
below should do it.
HabG_
Thanks Riyas,
It worked.
