help... i want  renderer point symbol but my code is not work
5328
11
08-21-2014 12:00 AM
lasinh
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
  <title>Create a Map</title>
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.10/js/esri/css/esri.css" />
  <script type="text/javascript">      dojoConfig = { parseOnLoad: true };</script>
  <script type="text/javascript" src="http://js.arcgis.com/3.10/"></script>
  <style>
    html, body, #mapDiv, .map.container {
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      dojo.require("dojo.date.locale");
      function init() {
          var initialExtent = new esri.geometry.Extent({ "xmin": -163.01, "ymin": 3.52, "xmax": 51.96, "ymax": 64.17, "spatialReference": { "wkid": 4326} });
          var map = new esri.Map("mapDiv", {
              extent: esri.geometry.geographicToWebMercator(initialExtent)
          dojo.connect(window, 'resize', map, map.resize);
          var basemapURL = "http://192.166.3.252:6080/arcgis/rest/services/NENCHUNG/Nen_chung1/MapServer";
         var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapURL);
         map.addLayer(basemap);
          //define info window and format contents https://developers.arcgis.com/javascript/jsapi/infotemplate-amd.html
          var template = esri.InfoTemplate({
              title: "${ten}",
              content: "<br>${ten}, ${diaChi}"
          var featureLayer = new esri.layers.FeatureLayer("http://192.166.3.252:6080/arcgis/rest/services/NENCHUNG/Nen_chung1/MapServer/2", {
              infoTemplate: template,
              outFields: ["*"]
          //resize the info window
          map.infoWindow.resize(160, 80);
          //add a layer definition to filter to display the features
//          featureLayer.setDefinitionExpression("Tour = 'Unforgettable Fire 2nd Leg'");
          //define new symbol for feature layer - generated with https://developers.arcgis.com/javascript/jshelp/inside_renderers.html
          var symbol = new esri.symbol.PictureMarkerSymbol({
              "angle": 0,
              "xoffset": 0,
              "yoffset": 10,
              "type": "esriPMS",
              "url": "http://static.arcgis.com/images/Symbols/Shapes/BluePin1LargeB.png",
              "contentType": "image/png",
              "width": 24,
              "height": 24
          featureLayer.setRenderer(new esri.renderer.SimpleRenderer(symbol));
          map.addLayer(featureLayer);
      dojo.addOnLoad(init);
  </script>
</head>
<body class="claro">
<div id="mapDiv"></div>
</body>
</html>
RiyasDeen
Hi Ia,
I tested your code with an ESRI dynamic map service. working as charm!
Can you post a screenshot of what output you are getting for this url http://192.166.3.252:6080/arcgis/rest/services/nen_chung2/Nen_chung2/MapServer?
If the response of above URL contains Tile Info then your map service is not a tiled map service.
I suspect your map service is actually tiled.
RiyasDeen
Hi Ia,
One thing that stands out i your code is, you are using same map service for creating a tiled map service object and feature layer. you can't use this combination.
If your map service is tiled then you can't use it as a feature layer.
If you map service is dynamic (which is suspect it is) you need create a ArcGISDynamicMapServiceLayer.
Refer this sample. Edit fiddle - JSFiddle
lasinh
there is an example at api acgis for javascript use tiled map service , it still works normally. Map with popup tutorial | ArcGIS API for JavaScript‌. but my code is not work
RiyasDeen
Hi Ia,
If you notice the sample you referred, base map is created from a tiled map service but the FeatureLayer is created from a feature service.
In your case you are creating the base map and feature layer from the same map service.
lasinh
thanks Riyas, i created ArcGISDynamicMapServiceLayer, my code still not render symbol point on map layer. this is my code, please help me!!!
<html>
<head>
  <style>
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
      function init() {
  var basemapURL = "http://192.166.3.252:6080/arcgis/rest/services/nen_chung2/Nen_chung2/MapServer‌";
         var basemap = new esri.layers.ArcGISDynamicMapServiceLayer(basemapURL);
              title: "${ten}",
          var featureLayer = new esri.layers.FeatureLayer("http://192.166.3.252:6080/arcgis/rest/services/nen_chung2/Nen_chung2/MapServer‌/2", {
              outFields: ["*"]
          //define new symbol for feature layer - generated withhttps://developers.arcgis.com/javascript/jshelp/inside_renderers.html
              "angle": 0,
              "xoffset": 0,
              "yoffset": 10,
              "type": "esriPMS",
              "width": 24,
              "height": 24
  </script>
</head>
</body>
</html>
RiyasDeen
Hi Ia,
RiyasDeen
Correction:
lasinh
RiyasDeen
Hi Ia,
Are you able to render your point layer now?
lasinh
Hi Riys, i try render layer Congtrinh(2), but symbol not render on map!!!
