HTML Popup Opens Wrong Image
2848
08-20-2014 12:49 PM
ShantelleLopez
Any assistance with this would be appreciated.  I enabled attachments on a feature class and ran the add attachments tool. My feature class already had the path to an image, so I set my match table to the feature class I wanted to attach the image to.   When I use the hyperlink next to the field which contains the path the correct image displays.  However, the HTML popup dialog box displays the wrong image; It seems to be switching between three or four images no matter which feature is selected.  The 3 to 4 images change each time the map document is loaded.
Has anyone seen this before?  Any workarounds?
Thanks.
