Create Token VB.Net
10049
08-18-2014 12:41 PM
jaykapalczynski
Honored Contributor
Trying to create a Token at my initial login page.
I think I may have some syntax error but cant figure out where....ANY ideas?
Imports System.Data.SqlClient
Imports System.Net.Mail
Imports System.Data
Imports System.IO
Imports System.Web.Configuration
Imports System.Web.UI
Imports System.Net
Partial Class Login
Inherits System.Web.UI.Page
Public username As String = ""
Public password As String = ""
Protected Sub LoginButton_Click(sender As Object, e As EventArgs)
      username = Login1.UserName
      password = Login1.Password
      Session("username") = username
      Session("password") = password
     Dim sConn As String
      sConn = System.Configuration.ConfigurationManager.ConnectionStrings("SQLConnection").ToString
     Dim sqlConn As New SqlConnection(sConn)
     Dim sqlcomm As New SqlCommand("select * from users_test where username='" & username & "'and password ='" & password & "'", sqlConn)
      sqlcomm.CommandType = Data.CommandType.Text
     Dim rdrloginexists As SqlDataReader
      sqlConn.Open()
      rdrloginexists = sqlcomm.ExecuteReader
     Dim myDT As DataTable = New DataTable
       myDT.Load(rdrloginexists)
      sqlConn.Close()
      Create_Token(username, password, "123456")
End Sub
Public Sub Create_Token(ByVal username As String, ByVal password As String, ByVal clientid As String)
           Dim referer As String = "http://ourServer.gov/login.aspx"
     Dim expiration = "2014"
     Dim tokenUrl As String = "https:/http://ourServer.gov/login.aspx/Create_Token?username=" & username & "&password=" & password & "&referer=" & referer & "&expiration=" & expiration & "&f=json"
     Dim tokenRequest = DirectCast(WebRequest.Create(tokenUrl), HttpWebRequest)
      tokenRequest.Referer = referer
     Dim token1 = tokenRequest.GetResponse()
     Using stream As Stream = token1.GetResponseStream()
          Dim reader As New StreamReader(stream, Encoding.UTF8)
          Dim responseString As [String] = reader.ReadToEnd()
     End Using
End Sub
End Class
jaykapalczynski
Honored Contributor
I was able to get this working.....
ANY Questions PLEASE ASK
I have an .aspx with .aspx.vb LOGIN page that grabs the user Credentials and other necessary parameters for  creating a Token...the token is created at the login page and stored as a session variable which is then consume in the redirect page.  Once at this new page I am using this created TOKEN to render my Secured Services WITHOUT having the login again....
Imports System.Data
Imports System.IO
Imports System.Net
Partial Class Login
        Dim username As String
        Dim password As String
        Dim sConn As String
        sqlConn.Open()
        If myDT.Rows.Count <> 0 Then
            Create_Token(username, password)
            Response.Redirect("Test.aspx")
        End If
        sqlConn.Close()
    End Sub
    Public Sub Create_Token(ByVal username As String, ByVal password As String)
        Dim referer As String = "https://OurServer.gov"
        Dim expiration As String = "120"
        Dim format As String = "json"
       ' This will be replaced with the Actual IP of the requester....dont have that code yet...hard coded for now
        ' Replace with your IP Address
        Dim clientid As String
        clientid = "10.111.11.111"
        Dim tokenUrl As String = "https://OurServer.gov/arcgis/tokens?request=gettoken&username=" & username & "&password=" & password & "&referer= & referer & clientid=" & clientid & "expiration=" & expiration & "&f=" & format & ""
        Dim tokenRequest As New WebClient
        Dim token = System.Text.Encoding.UTF8.GetString(tokenRequest.DownloadData(tokenUrl))
        Session("tokentext") = token
    End Sub
End Class
jaykapalczynski
Honored Contributor
Am I wrong on the String ...maybe something like this
Dim referer As String = "https://MyServer.gov/login.aspx"
Dim expiration = "10"
Dim tokenUrl As String = "https://MyServer.gov/arcgis/tokens?request=gettoken & username=" &username & "&password=" & password & "&referer=" & referer & "&expiration=" & expiration & "& f=json"
Anyone ever bypass the User Name authentication via VB.net in a JavaScript app?  I have a password for my main Website...then have a bunch of apps inside...I dont want the user to have to enter password 5 million times..
jaykapalczynski
Honored Contributor
Imports System.Data
Imports System.IO
Imports System.Net
Partial Class Login
        Dim sConn As String
        sqlConn.Open()
        End If
        sqlConn.Close()
    End Sub
    End Sub
End Class
ShaikhRizuan
Hi Jay,
The token generated does not respect the referer URL. If token is being used in any other application, i can see the map.
Actually it should not allow to view the map.  I have posted the issue in detail in below link
https://community.esri.com/thread/207940-arcgis-token-not-working-properly-when-creating-programmati...
How to resolve this??
