arcgis server on linux
3639
08-17-2014 10:02 PM
jayasudha
hello experts
we have oracle 11g R2 server on linux 5
If i install arcgis server (10.1) on different machine running redhat linux 5, how to make arcsde direct connections ? can we configure arcgis server on linux to use arcsde direct connection files (.sde) ?
do we need to work with arcsde application server connection ?
please help
VinceAngelo
Esri Esteemed Contributor
Yes, of course you can publish services using Direct Connect.  You simply need to install the appropriate 64-bit client on the server, and register the data source within the Server instance.
- V
DanPatterson_Retired
I presume that you have been through these links?
jayasudha
hi
i have been through the links.
i have arcgis desktop 10.1 installed on my local machine (windows 7).
Can i author and publish map service from arcgis desktop 10.1 running on my local machine on windows 7 by connecting arcgis server 10.1 running on redhat linux ?
VinceAngelo
- V
jayasudha
Thanks Vince
